HDD GURU FORUMS
http://forum.hddguru.com/
READ Channel 0n 2060-800022 PCB
http://forum.hddguru.com/viewtopic.php?f=11&t=34519
Page 1 of 1
Author:  Murtazah [ November 16th, 2016, 9:09 ]
Post subject:  READ Channel 0n 2060-800022 PCB
I had WD20NMVW-11C3NS2 with USB Interface PCB 2060-800041. Changed to compatible 2060-800022. After connecting It comes to Ready State but gets to BSY on HDD ID. I Have tried Isolating head contacts from PCB but it remains BSY only.
Please provide Read Channel points which to short to get to SA access.
thank you all
Author:  MindMergepk [ November 16th, 2016, 9:14 ]
Post subject:  Re: READ Channel 0n 2060-800022 PCB
you can try to connect only pcb and block SA access in ROM.
Author:  Murtazah [ November 16th, 2016, 9:42 ]
Thanks for quick reply,
Connecting only PCB also remains in BSY state forever.
Attached is PCB image.
Author:  jermy [ November 16th, 2016, 12:54 ]
You read the ROM in boot ROM mode and block SA manually
Author:  fzabkar [ November 16th, 2016, 15:16 ]
Murtazah wrote:
Please provide Read Channel points...
TV9 and TV10 ?
http://www.phpbb.com/
