 Post subject: HELP!!! SSD Micro!!!
PostPosted: November 23rd, 2016, 22:07
I hope you are doing great.
I have this SSD Storage Micro of 256GB (Lingston Technology) i have connected to a adapter SSD to SATA, it is very hot and PC3000 wont autodetect.
Not sure next steps and it would be great a suggestion.
Thank you for the help.
Best regards,
 Post subject: Re: HELP!!! SSD Micro!!!
PostPosted: November 24th, 2016, 14:15
Hi olinyer, Have you got a picture of it? Which part is getting hot? Main controller, memories?
Best
F
PostPosted: November 24th, 2016, 14:23
A photo of the adapter would be advisable, IMHO. It could be that the wrong adapter is being used.
PostPosted: November 24th, 2016, 15:10
adding pic.
the memories (two NAND Chips) are the one getting very hot
i thought in the kind of adapter as well
thank you for the help.
Best regards,
PostPosted: November 24th, 2016, 16:04
Hello! I can t realize looking at the pictures...but were the memories reworked (unsoldered and re-soldered)?
Only 2 of the 4 memories are getting hot?
Best,
F
PostPosted: November 24th, 2016, 17:12
Here are photos of the adapter:
http://cdn1.image-tmart.com/prodimgs_v2/8/8101/0925/81010925/M817-mSATA-SSD-to-25-SATA-Adapter-Card-25cm_800x800.jpg?1388195215 (component side)
https://contestimg.wish.com/api/webimage/54002853ecdd3054d195a166-4-large.jpg (back)
The voltage at the tab of U1 (LT1084-33) should be +3.3V.
AFAICT, the SSD (Kingston SMSR150S3/256G mSATA) is a RAID with a separate SSD on each side.
    Phison PS3108-S8-I controller
    Elpida EDJ2116DEBG 2Gbit DDR3 SDRAM
    2 x Toshiba TH58TEG8DDJBA82 NAND flash (64GB ?)
The adapter expects to see a single SSD. Therefore I would be very concerned with the pinout. Perhaps it is non-standard? I would determine the ground pins with a multimeter, and also confirm the +3.3V pins by testing for continuity with U1.
EDJ2116DEBG, Elpida, 2Gbits DDR3 SDRAM, 128Mwords x 16bits, 1.5V:
http://tabreview.ru/content/pdf_docs/El ... G_DJ_F.pdf
LT1084-33, Linear Tech, 5A, 3.3V, LDO Regulator:
http://www.farnell.com/datasheets/1941079.pdf
PS3108-S8 product brief:
http://www.phison.com/English/newProductView.asp?ID=237&SortID=63
    Operating Voltage: 0.9 ~ 3.6V
    Built-in Regulator that supports 3.3V/1.8V Flash I/O
