Cannot recover Translation ST9500325AS ?
Posted: December 20th, 2016, 7:05
I have ST9500325AS, all heads goods (can read using utilities ) and when i try to recover translation stay forever ????
HDD family detecting...
Family ID: 3C
Selected family......................... : 3C, Wyatt
Model by ID............................. : ST9500325AS
Loading default settings!
Use the options dialog to review and save utility settings.
Then press OK!
Family default settings loading!
Tech Key...
Requesting FW Pkg ver ........ WY05D7.SDM1.DA99L2.0002SDM1
Detecting Phys Sct Size...
Result.................................. : 512
Detecting Max Head number...
Phys. heads............................. : 4
Obtaining Saved Mode Pages File information...
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
SMP Dbl: 0x3C000317 - 0x037FF7FF (0x0000000F)
LBA alignment........................... : 0
Obtaining Registry File information...
Reading Registry File...
Parsing Registry File...
Media Cache
MC is not supported / NVC caching
Collecting Sys Files information...
ID Len
0 2 Reserved Defect Table (SA defect table)
1 2 Drive Information File (DIF)
2 16 Performance Parameter File (PPF)
3 1870 Primary Defect File (P-List))
4 9 Servo Adaptive Parameter File (SAP)
5 4 Manufacturing Information File (MIF)
6 85 Read Adaptive Parameters File (RAP)
7 1 Controller Adaptive Parameters File (CAP)
8 2400
9 1 SMART Configuration File
A 2251 SMART Data File
B 1000
C 64000 Serial Port Test Results File (Self Scan Log)
D 160
E 432 Data Integrity Check (DIC), HEAD 0
F 223 DIC Dummy File
13 8 Disc Registry File (settings, security, etc)
15 100 BGMS File (Directed Offline Scan)
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
1D 128 Physical Overlay File 0
1E 128 Physical Overlay File 1
1F 640 Physical Overlay File 2
22 80 Drive Self Test (DST), Head 0
23 80 Drive Self Test (DST), Head 1
24 80 Drive Self Test (DST), Head 2
25 80 Drive Self Test (DST), Head 3
2A 9 Saved Mode Pages (HDD settings)
2B 535 R/W Operating Parameters (translator, etc)
2C 432 Data Integrity Check (DIC), HEAD 1
2D 432 Data Integrity Check (DIC), HEAD 2
2E 432 Data Integrity Check (DIC), HEAD 3
33 4576
34 640 Packed CONGEN XML definition
35 26 SMART Data
Collecting Sys File Infos completed
Collecting DT Infos...
ROM:
ID MemOffs Len
0 6020100 43520 Read Adaptive Parameters File (RAP)
1 6020000 256 Controller Adaptive Parameters File (CAP)
4 4000000 4096 Servo Adaptive Parameter File (SAP)
5 6C000 81920 Servo Firmware Table
A 60A22AC 1024 Seek Profile
13 60AD308 768 Dependent Zone Table for User Area
14 60AD608 64 Dependent Zone Table for System Area
15 0 524288 Flash ROM
1B 60AC0F0 4632 Dependent Zone Group Tables for User Area
1C 60ABFB0 320 Dependent Zone Group Tables for System Area
1D 6020120 208 VBAR Configuration File
1E 6020380 3216 Zone Format Parameters File
RAM:
ID MemOffs Len
2 60201F0 400 Zone Table
6 227840 40996 Servo Flaw Table
16 6020100 32 Drive Configuration Table
17 6022A60 1616 Temperature Control Configuration
1F 6144678 1728 RW working user preamp table
20 6144D38 72 RW working system preamp table
Collecting DT Infos completed
Reading autotuning buffer............... Ok
Searching module table in RAM... ....... Ok
Searching volume 3 file table in RAM.... Ok
Searching volume 0 file table in RAM.... Ok
Searching SMP RAM FID in RAM............ Ok
Searching Non Resident G-List FID in RAM Ok
Searching CFW OVL FID in RAM............ Ok
Searching DT table(RAM, WR) in RAM...... Ok
Searching DT table(RAM, RD) in RAM...... Ok
System Files I/O method detection... ATA(indirect)
Test : Recover translator
First start
Translation "forks" list file........... : C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Wyatt\ST9500325AS-0002SDM1-5VE8RX4E\Defects\TranslationForks.lba
Maximal defect chain length............. : 64
Take into account P-List................ : Yes
At ambiguity hide "left" UNC............ : Yes
Process "32 byte tail" bug.............. : Yes
Execute Reset after defect hiding....... : Yes
HDD resources backup
Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Wyatt\ST9500325AS-0002SDM1-5VE8RX4E\Data\SABackup\
Backup of service information completed
Switching Autoreassign OFF...
Writing Saved Mode Pages...
HDD power supply switching OFF/ON...
G-List erase...
Translator regeneration...
Result.................................. : Ok
HDD ID reading...
Detecting defects hiding cmd type...
G-List erase...
Start scanning...
"Fork" searching: 0 - 976773167
Verify sectors ext error Device error detected "UNC"
PRd: Err Rd Ph Sect 131:2:0(1)! Tech state 0x72, 0x03160080
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:0(1)! Tech state 0x72, 0x03160080
LBA : 2122782
"Fork" searching: 2122783 - 976773167
PRd: Err Rd Ph Sect 131:2:1(1)! Tech state 0x72, 0x03160080
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:1(1)! Tech state 0x72, 0x03160080
LBA : 2122783
"Fork" searching: 2122784 - 976773167
PRd: Err Rd Ph Sect 131:2:2(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:2(1)! Tech state 0x72, 0x03110081
LBA : 2122784
"Fork" searching: 2122785 - 976773167
PRd: Err Rd Ph Sect 131:2:3(1)! Tech state 0x72, 0x03160080
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:3(1)! Tech state 0x72, 0x03160080
LBA : 2122785
"Fork" searching: 2122786 - 976773167
PRd: Err Rd Ph Sect 131:2:4(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:4(1)! Tech state 0x72, 0x03110081
LBA : 2122786
"Fork" searching: 2122787 - 976773167
PRd: Err Rd Ph Sect 131:2:5(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:5(1)! Tech state 0x72, 0x03110081
LBA : 2122787
"Fork" searching: 2122788 - 976773167
PRd: Err Rd Ph Sect 131:2:6(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:6(1)! Tech state 0x72, 0x03110081
LBA : 2122788
"Fork" searching: 2122789 - 976773167
PRd: Err Rd Ph Sect 131:2:7(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:7(1)! Tech state 0x72, 0x03110081
LBA : 2122789
"Fork" searching: 2122790 - 976773167
PRd: Err Rd Ph Sect 131:2:9(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:9(1)! Tech state 0x72, 0x03110081
LBA : 2122791
"Fork" searching: 2122792 - 976773167
PRd: Err Rd Ph Sect 131:2:A(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:A(1)! Tech state 0x72, 0x03110081
LBA : 2122792
"Fork" searching: 2122793 - 976773167
PRd: Err Rd Ph Sect 131:2:B(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:B(1)! Tech state 0x72, 0x03110081
LBA : 2122793
"Fork" searching: 2122794 - 976773167
PRd: Err Rd Ph Sect 131:2:C(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:C(1)! Tech state 0x72, 0x03110081
LBA : 2122794
"Fork" searching: 2122795 - 976773167
PRd: Err Rd Ph Sect 131:2:D(1)! Tech state 0x72, 0x03160080
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:D(1)! Tech state 0x72, 0x03160080
LBA : 2122795
"Fork" searching: 2122796 - 976773167
PRd: Err Rd Ph Sect 131:2:E(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:E(1)! Tech state 0x72, 0x03110081
LBA : 2122796
"Fork" searching: 2122797 - 976773167
PRd: Err Rd Ph Sect 131:2:F(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:F(1)! Tech state 0x72, 0x03110081
LBA : 2122797
"Fork" searching: 2122798 - 976773167
PRd: Err Rd Ph Sect 131:2:10(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:10(1)! Tech state 0x72, 0x03110081
LBA : 2122798
"Fork" searching: 2122799 - 976773167
PRd: Err Rd Ph Sect 131:2:11(1)! Tech state 0x72, 0x03160080
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:11(1)! Tech state 0x72, 0x03160080
LBA : 2122799
"Fork" searching: 2122800 - 976773167
PRd: Err Rd Ph Sect 131:2:12(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:12(1)! Tech state 0x72, 0x03110081
LBA : 2122800
"Fork" searching: 2122801 - 976773167
PRd: Err Rd Ph Sect 131:2:17(1)! Tech state 0x72, 0x03160080
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:17(1)! Tech state 0x72, 0x03160080
LBA : 2122805
"Fork" searching: 2122806 - 976773167
PRd: Err Rd Ph Sect 131:2:18(1)! Tech state 0x72, 0x03110081
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:18(1)! Tech state 0x72, 0x03110081
LBA : 2122806
"Fork" searching: 2122807 - 976773167
PRd: Err Rd Ph Sect 131:2:19(1)! Tech state 0x72, 0x03160080
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:19(1)! Tech state 0x72, 0x03160080
LBA : 2122807
"Fork" searching: 2122808 - 976773167
PRd: Err Rd Ph Sect 131:2:1A(1)! Tech state 0x72, 0x03160080
Surface scanning error (UNC) : PRd: Err Rd Ph Sect 131:2:1A(1)! Tech state 0x72, 0x03160080
LBA : 2122808
"Fork" searching: 2122809 - 976773167
PRd: Terminated by user : Error requesting command state "Rd Ph Sect" (Drive is not ready)
Key:Terminated by user
Surface scanning error (UNC) : PRd: Terminated by user : Error requesting command state "Rd Ph Sect" (Drive is not ready)
LBA : 2122809
"Fork" searching: 2122810 - 976773167
Verify sectors ext error Operation aborted
LBA : 2122810
Family ID: 3C
Then press OK!
Tech Key...
Media Cache
ID Len
8 2400
B 1000
D 160
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
33 4576
35 26 SMART Data
ROM:
ID MemOffs Len
RAM:
ID MemOffs Len
First start
G-List erase...
HDD ID reading...
G-List erase...
Start scanning...
LBA : 2122782
LBA : 2122783
LBA : 2122784
LBA : 2122785
LBA : 2122786
LBA : 2122787
LBA : 2122788
LBA : 2122789
LBA : 2122791
LBA : 2122792
LBA : 2122793
LBA : 2122794
LBA : 2122795
LBA : 2122796
LBA : 2122797
LBA : 2122798
LBA : 2122799
LBA : 2122800
LBA : 2122805
LBA : 2122806
LBA : 2122807
LBA : 2122808
LBA : 2122809
LBA : 2122810
