 Post subject: Another WD ROM request!!
PostPosted: January 10th, 2017, 7:08
DragFly 3
Ver 00900099
Drive model: WD15EADS-00P8B0
Cheers!!
 Post subject: Re: Another WD ROM request!!
PostPosted: January 10th, 2017, 8:28
Sorry, too many 9´s. I don´t have that one :(
PostPosted: January 10th, 2017, 9:27
Thanks anyway! :)
PostPosted: January 10th, 2017, 9:34
pcimage wrote:
DragFly 3
Ver 00900099
Cheers!!
try this 00900014
WD15EADS-00P8B0.rar [529.29 KiB]
Downloaded 725 times
PostPosted: January 10th, 2017, 12:37
Thanks but I need 900099 :-(
PostPosted: January 10th, 2017, 20:31
Deleted
PostPosted: January 11th, 2017, 3:18
heheh
Sean, this was the only one i got close to ur req.
i really don`t know from where your getting those drives :shock:
PostPosted: January 11th, 2017, 3:56
einstein9 wrote:
heheh
It's some refurbished crap! :-(
PostPosted: January 12th, 2017, 5:59
pcimage wrote:
einstein9 wrote:
heheh
Had to chk my very old SD stock, found those 00900073 0090009A
i don`t think digging more will find better than those.
good luck :wink:
DF3.rar [1.04 MiB]
Downloaded 723 times
PostPosted: January 12th, 2017, 8:38
From a WD10xxxx DragFly"2"
ROM_00900099.rar [175.4 KiB]
Downloaded 663 times
PostPosted: January 12th, 2017, 9:26
Thanks, but didn't work.
I need a DragFly3 ROM :-(
PostPosted: January 12th, 2017, 10:22
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 4
>Cyl Count............................... : 192
>ROM:
>Read ROM................................ : Ok
>ROM Data size........................... : 192 Kb
>Flash ROM dir reading................... : Ok (Active)
>Flash ROM dir reading (Ext)............. : Ok
>Modules directory address............... : 77 995
>SA regions address...................... : by default
>Module 02 access........................ : Granted
>SA Translator loading................... : Ok
>ROM Modules:
>ROM version............................. : 90.99N
>ROM F/W version......................... : 00900099
>Overlay F/W version..................... : 90.99N
>Servo F/W version....................... : 03.09
ROM_90-99N_90-99N_03-09.rar [175.6 KiB]
Downloaded 686 times
PostPosted: January 12th, 2017, 16:28
northwind wrote:
>Techno mode key
>RAM:
>ROM:
>ROM Modules:
Thanks Dimitris, will try that tomorrow :-)
PostPosted: January 13th, 2017, 7:35
Worked fine after changing the head map and using original mod 47 :-)
Cloning now.....
Cheers!!! :beer:
