Page 1 of 1
WD5000LMCW-11T31S1 to Sata ?
Posted: January 17th, 2017, 17:10
by hvd
Hello
I have a WD5000LMCW-11T31S1 hard drive, it makes noise.
I want to convert USB 3 to Sata to do the diagnosis with PC-3000.
There is PCB sata compatible with WD5000LMCW-11T31S1 ?
Thank you
Re: WD5000LMCW-11T31S1 to Sata ?
Posted: January 18th, 2017, 5:24
by hvd
Hello
My PCB is 2060-800038-000 Rev P1. He's not on the list.
Do you have another solution?
Thank you
Spildit wrote:Check PCB NUMBER.
Then check :
http://www.hddoracle.com/viewtopic.php?f=7&t=1080
Posted: January 18th, 2017, 12:21
by hdd_sand
I used 2060-800025-001
