 Post subject: When to use soft reset vs hard reset?
PostPosted: February 8th, 2017, 0:16
Looking through the manual, when should I send a drive a soft reset vs a hard reset? Is there an ELI5 version of what the SRST bit is in relation to "drive interface circuit?"
 Post subject: Re: When to use soft reset vs hard reset?
PostPosted: February 8th, 2017, 10:46
There is no specific rule. Matter of fact, besides obviously the surface condition, it is more drive model/family related. You will see trends of specific drive behavior, which typically will result in more or less specific imaging parameter settings. The default settings in general are a good start.
