| When to use soft reset vs hard reset? http://forum.hddguru.com/viewtopic.php?f=11&t=34956 |
Page 1 of 1 |
| Author: | JGAN [ February 8th, 2017, 0:16 ] |
| Post subject: | When to use soft reset vs hard reset? |
Looking through the manual, when should I send a drive a soft reset vs a hard reset? Is there an ELI5 version of what the SRST bit is in relation to "drive interface circuit?" |
| Author: | labtech [ February 8th, 2017, 10:46 ] |
| Post subject: | Re: When to use soft reset vs hard reset? |
There is no specific rule. Matter of fact, besides obviously the surface condition, it is more drive model/family related. You will see trends of specific drive behavior, which typically will result in more or less specific imaging parameter settings. The default settings in general are a good start. |
