| Strange Case ST500LT012 http://forum.hddguru.com/viewtopic.php?f=11&t=34979 |
Page 1 of 1 |
| Author: | MindMergepk [ February 12th, 2017, 8:40 ] |
| Post subject: | Strange Case ST500LT012 |
the drive in questin is spinning fine without any abnormal sound. get ID correctly, cam read all modules and sys files without any problem. BUT can't access user area !! here is the log: Quote: (P) SATA Reset RAW OFF (DOS) Debug enabled Intel 6G->3G Send Status: COMRESET seen PASS TotalSuperBlks 00069DF6 TotalValidSuperBlks 00069DED on the RESET : Quote: (P) SATA Reset RAW OFF (DOS) Debug enabled Intel 6G->3G Send Status: Phy Ready without COMRESET, Status=50 PASS TotalSuperBlks 00069DF6 TotalValidSuperBlks 00069DEDj Head resistance seems to be fine: Quote: F3 T>/7 F3 7>X Head 00 Resistance 021A Head 01 Resistance 022F F3 7> Ctrl X Log: Quote: F3 T> ATA 15 Cmds Ts(ms) dT(ms) Op Cnt LBA 0 99999999 00 0000 000000000000 0 0 00 0000 000000000000 0 0 00 0000 000000000000 0 0 00 0000 000000000000 0 0 00 0000 000000000000 0 0 00 0000 000000000000 0 0 00 0000 000000000000 0 0 00 0000 000000000000 0 0 00 0000 000000000000 0 0 00 0000 000000000000 0 0 00 0000 000000000000 0 0 00 0000 000000000000 0 0 00 0000 000000000000 0 0 00 0000 000000000000 0 0 00 0000 000000000000 RW 32 Cmds Ts(ms) dT(ms) xT(ms) Type Option Mode St EC Info 2468 99999999 9 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000542D L 00000004 BO 000000 BES 009B900.009B9FF.009B900 2477 9 5 02 008901 000000 1 00000080 XFR RD SYS LBA B 000000006933 L 00000001 BO 000000 BES 007184C.007188B.007184C 2483 6 10 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000B206 L 00000014 BO 000000 BES 00E1AC0.01DFFFF.00E1AC0 2505 22 11 02 008901 000000 1 00000080 XFR RD SYS LBA B 000000006934 L 00000001 BO 000000 BES 007178C.00717CB.007178C 2517 12 2 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000AFF5 L 00000001 BO 000000 BES 009B900.009BCFF.009B900 2519 2 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000000AFF5 L 00000001 BO 000000 BES 009B900.009B93F.009B900 2530 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000036551 L 00000001 BO 000000 BES 009B900.009B93F.009B900 2542 12 7 02 008901 000000 1 00000080 XFR RD SYS LBA B 000000004A8B L 00000001 BO 000000 BES 009B900.009B93F.009B900 2549 7 11 02 008901 000000 1 00000080 XFR RD SYS LBA B 000000004A8B L 00000001 BO 000000 BES 009B900.009B93F.009B900 2560 11 5 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000542D L 00000004 BO 000000 BES 009B900.009B9FF.009B900 2566 6 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000000542D L 00000010 BO 000000 BES 009B900.009BCFF.009B900 2577 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000030989 L 00000010 BO 000000 BES 009B900.009BCFF.009B900 2588 11 9 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000B002 L 00000002 BO 000000 BES 009B900.009BCFF.009B900 2597 9 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000000B002 L 00000002 BO 000000 BES 009B900.009B97F.009B900 2608 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000003655E L 00000002 BO 000000 BES 009B900.009B97F.009B900 2619 11 11 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000B002 L 00000002 BO 000000 BES 009B900.009BCFF.009B900 2630 11 5 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000004977 L 00000001 BO 000000 BES 009CCC0.009CCFF.009CCC0 2635 5 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000002FED3 L 00000001 BO 000000 BES 009CCC0.009CCFF.009CCC0 2646 11 11 02 008901 000000 1 00000080 XFR RD SYS LBA B 000000005540 L 00000008 BO 000000 BES 009B900.009BCFF.009B900 2657 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000005540 L 00000008 BO 000000 BES 009B900.009BAFF.009B900 2668 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000030A9C L 00000008 BO 000000 BES 009B900.009BAFF.009B900 2679 11 3 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000006933 L 00000001 BO 000000 BES 007184C.007188B.007184C 2682 3 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000031E8F L 00000001 BO 000000 BES 007184C.007188B.007184C 2694 12 4 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000542D L 00000004 BO 000000 BES 009B900.009B9FF.009B900 2699 5 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000000542D L 00000010 BO 000000 BES 009B900.009BCFF.009B900 2710 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000030989 L 00000010 BO 000000 BES 009B900.009BCFF.009B900 2721 11 14 02 008901 000000 1 00000080 XFR RD SYS LBA B 0000000258B2 L 00000088 BO 000000 BES 00D01EC.00D23EB.00D01EC 2736 15 28 02 008901 000000 1 00000080 XFR RD SYS LBA B 0000000268DA L 00000968 BO 000000 BES 00A9F00.00CF8FF.00A9F00 2782 46 8 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000000493D L 00000008 BO 000000 BES 0071B8C.0071D8B.0071B8C 2790 8 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000002FE99 L 00000008 BO 000000 BES 0071B8C.0071D8B.0071B8C 3731 941 80 38 014101 000000 1 00000080 PWR Mode 101 11941 8210 190 38 014101 000000 1 00000080 PWR Mode 102 when try to read any sector: Quote: Starting LBA of RW Request=00000100 Length=FFFFFFFF ProcessRWError -Read- at LBA 00000100 Sense Code=43110081 SP is invalid Unrecoverable Error Reported So far I have tried a donor pcb, Translation Regeneration, s.m.a.r.t clear, disable media cache etc with no luck. Translator recovery did't work on it. will highly appreciate any help. regards |
| Author: | microsoftengineer [ February 12th, 2017, 9:34 ] |
| Post subject: | Re: Strange Case ST500LT012 |
check sys files may be some files r damage thats why this happens. |
| Author: | Amarbir[CDR-Labs] [ February 16th, 2017, 12:15 ] |
Baijaan, Try a head swap in this once and see |
| Author: | MindMergepk [ March 8th, 2017, 15:55 ] |
heads are fine, i have tested donor heads and problem is same. |
| Author: | jerry1 [ April 28th, 2017, 4:12 ] |
check 17a |
