| Case 1TB Helios http://forum.hddguru.com/viewtopic.php?f=11&t=35030 |
Page 1 of 1 |
| Author: | jerovsek [ February 21st, 2017, 9:02 ] |
| Post subject: | Case 1TB Helios |
Hello, I convert drive from USB to SATA trasnfer ROM and replace heads on Helios 1TB drive. Drive is ready and I start imaging to another drive connected to SATA1 port PC3000 UDMA On the begining process was slow, then run smoothly, now is slow again. I was able to image about 20% of drive. Now it reads some few k OK, then some part not read (few 100). If I stop process and turn off and on and start process it reread unread part ok, but very quick become unstable (read/skip). Currently reading 128 skip sectors 48 I try also to disable some of heads without success. Question. Could be reason of such behavior heads or something else. And if I stop process, replace heads with new one, how is with destination drive. Could I connect it to USB or internal SATA conector instead of SATA1 port of PC3000, or it needs to be connected on SATA 1 port of PC3000. How DE handles task. Thank you |
| Author: | jermy [ February 21st, 2017, 10:11 ] |
| Post subject: | Re: Case 1TB Helios |
Check the heads under a microscope, sounds contamination to me |
| Author: | jerovsek [ February 21st, 2017, 13:58 ] |
thank you jermy |
