 Post subject: WD10JPCX resources
PostPosted: February 24th, 2017, 8:42
Hi, guys.
I need resources (LDR ) for drive WD10JPCX-24UE4TO
FBlite 2.5" family
ROM F/W Version: 0016002C
 Post subject: Re: WD10JPCX resources
PostPosted: February 24th, 2017, 10:36
Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 4
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1437
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM version............................. : 16.2CG
>ROM generation.......................... : 16.2DG
>Link table version...................... : NB.18.
>Consolidated ROM version................ : 0016002C
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Flash ROM dir reading (Ext)............. : Ok (Active)
>Modules directory address............... : 183 506
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 4
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,3
>ROM Firmware version.................... : 0016002C
>Service area:
>Permanent overlay....................... : Loaded
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1,Copy 2,Copy 3
11.rar [438.48 KiB]
Downloaded 669 times
PostPosted: February 24th, 2017, 10:45
Full resources...
http://files.hddguru.com/index.php?acti ... ty/Fblite&
PostPosted: February 25th, 2017, 1:11
@ pcimage
Thanks ...
appreciate your effort
It worked.. and copying data now
:D
PostPosted: February 25th, 2017, 5:46
You're welcome :-)
