Need resources for Shrek
http://forum.hddguru.com/viewtopic.php?f=11&t=35171
Author:  Nick_CT [ March 22nd, 2017, 5:00 ]
Post subject:  Need resources for Shrek
Hi all
Looking for resources for Shrek WD20NMVW-11W68S0 - Thanks.
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 8
Cyl Count............................... : 256
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 273 350
SA regions address...................... : by default
SA Translator loading................... : Ok
SA defects assigned..................... : 5
ROM Modules:
ROM version............................. : 04.18M
ROM F/W version......................... : 00040018
Overlay F/W version..................... : 04.18M
Servo F/W version....................... : T4.07
Heads configuration..................... : by map
Heads number in use..................... : 8
Switched off heads...................... : No
Heads map............................... : 0,1,2,3,4,5,6,7
Author:  einstein9 [ March 22nd, 2017, 5:15 ]
Post subject:  Re: Need resources for Shrek
here u go
good luck
00040018.rar [608.57 KiB]
Downloaded 622 times
Author:  Nick_CT [ March 22nd, 2017, 5:16 ]
Thank you
