 Post subject: Strange Case ST500LT012
PostPosted: February 12th, 2017, 8:40
the drive in questin is spinning fine without any abnormal sound.
get ID correctly, cam read all modules and sys files without any problem. BUT can't access user area !!
here is the log:
(P) SATA Reset
RAW OFF
(DOS) Debug enabled
Intel 6G->3G
Send Status: COMRESET seen PASS
TotalSuperBlks 00069DF6 TotalValidSuperBlks 00069DED
on the RESET :
(P) SATA Reset
RAW OFF
(DOS) Debug enabled
Intel 6G->3G
Send Status: Phy Ready without COMRESET, Status=50 PASS
TotalSuperBlks 00069DF6 TotalValidSuperBlks 00069DEDj
Head resistance seems to be fine:
F3 T>/7
F3 7>X
Head 00 Resistance 021A
Head 01 Resistance 022F
F3 7>
Ctrl X Log:
F3 T>
ATA 15 Cmds
Ts(ms) dT(ms) Op Cnt LBA
0 99999999 00 0000 000000000000
0 0 00 0000 000000000000
RW 32 Cmds
Ts(ms) dT(ms) xT(ms) Type Option Mode St EC Info
2468 99999999 9 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000542D L 00000004 BO 000000 BES 009B900.009B9FF.009B900
2477 9 5 02 008901 000000 1 00000080 XFR RD SYS LBA B 000000006933 L 00000001 BO 000000 BES 007184C.007188B.007184C
2483 6 10 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000B206 L 00000014 BO 000000 BES 00E1AC0.01DFFFF.00E1AC0
2505 22 11 02 008901 000000 1 00000080 XFR RD SYS LBA B 000000006934 L 00000001 BO 000000 BES 007178C.00717CB.007178C
2517 12 2 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000AFF5 L 00000001 BO 000000 BES 009B900.009BCFF.009B900
2519 2 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000000AFF5 L 00000001 BO 000000 BES 009B900.009B93F.009B900
2530 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000036551 L 00000001 BO 000000 BES 009B900.009B93F.009B900
2542 12 7 02 008901 000000 1 00000080 XFR RD SYS LBA B 000000004A8B L 00000001 BO 000000 BES 009B900.009B93F.009B900
2549 7 11 02 008901 000000 1 00000080 XFR RD SYS LBA B 000000004A8B L 00000001 BO 000000 BES 009B900.009B93F.009B900
2560 11 5 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000542D L 00000004 BO 000000 BES 009B900.009B9FF.009B900
2566 6 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000000542D L 00000010 BO 000000 BES 009B900.009BCFF.009B900
2577 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000030989 L 00000010 BO 000000 BES 009B900.009BCFF.009B900
2588 11 9 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000B002 L 00000002 BO 000000 BES 009B900.009BCFF.009B900
2597 9 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000000B002 L 00000002 BO 000000 BES 009B900.009B97F.009B900
2608 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000003655E L 00000002 BO 000000 BES 009B900.009B97F.009B900
2619 11 11 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000B002 L 00000002 BO 000000 BES 009B900.009BCFF.009B900
2630 11 5 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000004977 L 00000001 BO 000000 BES 009CCC0.009CCFF.009CCC0
2635 5 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000002FED3 L 00000001 BO 000000 BES 009CCC0.009CCFF.009CCC0
2646 11 11 02 008901 000000 1 00000080 XFR RD SYS LBA B 000000005540 L 00000008 BO 000000 BES 009B900.009BCFF.009B900
2657 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000005540 L 00000008 BO 000000 BES 009B900.009BAFF.009B900
2668 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000030A9C L 00000008 BO 000000 BES 009B900.009BAFF.009B900
2679 11 3 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000006933 L 00000001 BO 000000 BES 007184C.007188B.007184C
2682 3 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000031E8F L 00000001 BO 000000 BES 007184C.007188B.007184C
2694 12 4 02 008901 000000 1 00000080 XFR RD SYS LBA B 00000000542D L 00000004 BO 000000 BES 009B900.009B9FF.009B900
2699 5 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000000542D L 00000010 BO 000000 BES 009B900.009BCFF.009B900
2710 11 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 000000030989 L 00000010 BO 000000 BES 009B900.009BCFF.009B900
2721 11 14 02 008901 000000 1 00000080 XFR RD SYS LBA B 0000000258B2 L 00000088 BO 000000 BES 00D01EC.00D23EB.00D01EC
2736 15 28 02 008901 000000 1 00000080 XFR RD SYS LBA B 0000000268DA L 00000968 BO 000000 BES 00A9F00.00CF8FF.00A9F00
2782 46 8 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000000493D L 00000008 BO 000000 BES 0071B8C.0071D8B.0071B8C
2790 8 11 02 014101 000000 1 00000080 XFR WR SYS LBA B 00000002FE99 L 00000008 BO 000000 BES 0071B8C.0071D8B.0071B8C
3731 941 80 38 014101 000000 1 00000080 PWR Mode 101
11941 8210 190 38 014101 000000 1 00000080 PWR Mode 102
when try to read any sector:
Starting LBA of RW Request=00000100 Length=FFFFFFFF
ProcessRWError -Read- at LBA 00000100 Sense Code=43110081
SP is invalid
Unrecoverable Error Reported
So far I have tried a donor pcb, Translation Regeneration, s.m.a.r.t clear, disable media cache etc with no luck.
Translator recovery did't work on it.
will highly appreciate any help.
regards
Data Recovery Pakistan
 Post subject: Re: Strange Case ST500LT012
PostPosted: February 12th, 2017, 9:34
check sys files may be some files r damage thats why this happens.
PostPosted: February 16th, 2017, 12:15
Baijaan,
Try a head swap in this once and see
PostPosted: March 8th, 2017, 15:55
heads are fine, i have tested donor heads and problem is same.
PostPosted: April 28th, 2017, 4:12
check 17a
Users browsing this forum: No registered users and 14 guests
