| TOSHIBA MQ02ABF050H can't access all LBA http://forum.hddguru.com/viewtopic.php?f=11&t=35539 |
Page 1 of 1 |
| Author: | kimphonix [ July 4th, 2017, 0:55 ] |
| Post subject: | TOSHIBA MQ02ABF050H can't access all LBA |
Hello everyone, I have TOSHIBA MQ02ABF050H it can read ID but cannot access all sector. Could someone facing this problem and advice the solutions? Kindly advise Best regards, Kimphonix |
| Author: | Martin [ July 4th, 2017, 4:42 ] |
| Post subject: | Re: TOSHIBA MQ02ABF050H can't access all LBA |
It is SSHD, with high probability you have problem with NAND. If it is possible, please, provide terminal (diagnostic port, TTL) report. |
| Author: | kimphonix [ July 4th, 2017, 5:17 ] |
Hello Martin, Thank you for your reply. The initial message in utility looking good can read ID as follow Techno On............................... : Ok Zone table.............................. : Ok Cyl num................................. : 244 672 Head num................................ : 2 Vendor.................................. : TOSHIBA Model................................... : MQ02ABF050 Microcode............................... : HDFD2C0G Defects in G-List....................... : 0 CP Avalable............................. : 33,34,44,56,92,95,98,9A,9C,A2,A5,A7,A8,A9,AA,AD,AE,B1,B3,BB,BF,C1,C5,C6,C7,C8,C9,CB,CD,D0,D1,D3,D4,D6,D7,D9,DA,DB,DC,DD,EF,F1,F3,F4,F7,F8,FA,FB,FC,FE,FF And the message on terminal has just little as follow P90 FATAL P90 FATAL HF Best regards, Kimphonix |
