| please LDR for WD10EADS-11P8B2 1.0TB http://forum.hddguru.com/viewtopic.php?f=11&t=35713 |
Page 1 of 1 |
| Author: | ctanis [ August 16th, 2017, 4:12 ] |
| Post subject: | please LDR for WD10EADS-11P8B2 1.0TB |
I need LDR . ROM Modules: ROM version............................. : 15.1VD ROM F/W version......................... : 0015001V Overlay F/W version..................... : 15.1VD Servo F/W version....................... : 04.0P Also when I run utility I got error given below can you help me how can I solve this problem Techno mode key Techno mode key......................... : Ok RAM: HDD Info reading........................ : Ok Heads number............................ : 4 Cyl Count............................... : 192 Zone allocation table................... : HDDs RAM reading error Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended" ROM: Read ROM................................ : Ok ROM Data size........................... : 256 Kb Flash ROM dir reading................... : Ok Flash ROM dir reading (Ext)............. : Ok (Active) Modules directory address............... : 282 658 SA regions address...................... : by default Module 02 access........................ : Granted SA Translator loading................... : Ok ROM Modules: ROM version............................. : 15.1VD ROM F/W version......................... : 0015001V Overlay F/W version..................... : 15.1VD Servo F/W version....................... : 04.0P Heads configuration..................... : by map Heads number............................ : 6 Heads number in use..................... : 4 Switched off heads...................... : Yes Heads map............................... : 2,3,5,7 Service area: Permanent overlay....................... : Not loaded SA dir reading (ID)..................... : SERVO ERROR CODE BASE SvirActPdFail SA SPT Detect........................... : FAIL SA dir reading (ABA/CHS)................ : Module reading error: ABA 282 658(1) reading error Physical read error C/H/S: 373/0/159 Device Error Detected: "VSC ERR KEY SECTOR MUST PRECEED DATA XFER REQUEST" SA Access............................... : NONE Configuration reading................... : Module ID 02 reading error Data request error Device Error Detected: "Unknown error code: 3746" |
| Author: | MindMergepk [ August 16th, 2017, 15:13 ] |
| Post subject: | Re: please LDR for WD10EADS-11P8B2 1.0TB |
what is the behaviour of drive ? is it clicking ? or spin down ? tesukalar abi |
| Author: | ctanis [ August 17th, 2017, 0:31 ] |
There is unusual sound first spin up than spindown I thing there is a problem with heads and I want to try head map editing Do you have another idea .Also I think head cause bad sector on surface acording to sound.should I try change head map or fisrt open it in clean room but I dont have donor drive |
| Author: | lifeguarddubai [ August 17th, 2017, 1:51 ] |
HI, here it is ,,, http://files.hddguru.com/download/PC-30 ... 251248.zip[url][/url] |
| Author: | ctanis [ August 17th, 2017, 6:16 ] |
Thanks a lot:) |
