| WD drive isn't responding http://forum.hddguru.com/viewtopic.php?f=11&t=35762 |
Page 1 of 1 |
| Author: | Lylor [ August 31st, 2017, 5:11 ] |
| Post subject: | WD drive isn't responding |
Hello guys! I have WD drive which comes ready after power on but hangs when I'm trying start the Utility. Can somedody help me? |
| Author: | MindMergepk [ August 31st, 2017, 11:38 ] |
| Post subject: | Re: WD drive isn't responding |
what tools you are using ? can take a look remotely if interested good luck |
| Author: | lifeguarddubai [ September 3rd, 2017, 1:57 ] |
he is using Pc3000 i think as post is in Pc3000 Category ... |
| Author: | lifeguarddubai [ September 3rd, 2017, 2:00 ] |
hi, could you give more details about drive & Behavior when you power on . |
| Author: | hddguy [ September 4th, 2017, 8:42 ] |
Lylor wrote: Hello guys! I have WD drive which comes ready after power on but hangs when I'm trying start the Utility. Can somedody help me? sounds like common issue relating to device relocation parameters - clear parameters inside module #02 and empty #32 - you may need to force device into a ready state without loading current SA to RAM otherwise you will face BSY error constantly |
| Author: | Lylor [ November 22nd, 2017, 13:38 ] |
hddguy wrote: Lylor wrote: Hello guys! I have WD drive which comes ready after power on but hangs when I'm trying start the Utility. Can somedody help me? sounds like common issue relating to device relocation parameters - clear parameters inside module #02 and empty #32 - you may need to force device into a ready state without loading current SA to RAM otherwise you will face BSY error constantly Already forgot about my question here. Yes, it was like you said. There were problemas with clearing parameters but I managed! thank you |
