| seagate hdd tick tick after saving rom adaptives http://forum.hddguru.com/viewtopic.php?f=11&t=35885 |
Page 1 of 1 |
| Author: | mmzhr [ September 30th, 2017, 13:45 ] |
| Post subject: | seagate hdd tick tick after saving rom adaptives |
hi i changed rom adaptives in terminal after that i saved changes to rom with command /7w1,,22 but after reseting hdd spinup and i hear tick tick sound i think rom is damaged how can i fix damaged rom? |
| Author: | ccc [ October 2nd, 2017, 2:18 ] |
| Post subject: | Re: seagate hdd tick tick after saving rom adaptives |
By writing back the original ROM. |
| Author: | mmzhr [ October 2nd, 2017, 18:26 ] |
ccc wrote: By writing back the original ROM. i have eeprom programmer can i program original rom with programmer? |
| Author: | data-medics [ October 2nd, 2017, 18:28 ] |
You're in the PC-3000 support forum, so I assume you have PC-3000. Just use that to do it. |
| Author: | mmzhr [ October 2nd, 2017, 19:56 ] |
data-medics wrote: You're in the PC-3000 support forum, so I assume you have PC-3000. Just use that to do it. thanks but rom is damaged i have no terminal even in boot code i'm sure pcb is ok because i tested rom in donor pcb but no terminal |
| Author: | mmzhr [ October 4th, 2017, 3:55 ] |
Spildit wrote: Do you have PC-3000 ? sorry spildit i dont have pc3000 i posted topic in wrong forum |
