| ST1000LM035-1RK172 BSY http://forum.hddguru.com/viewtopic.php?f=11&t=36097 |
Page 1 of 1 |
| Author: | LostDataSa [ November 20th, 2017, 14:14 ] |
| Post subject: | ST1000LM035-1RK172 BSY |
Hi I got ST1000LM035-1RK172 it gets ready and Drive ID is full and correct but the terminal is non stop repeating the last code and when I do sector edit it get BSY and Stay BSY and I have no terminal access here is what terminal shows Code: Boot 0x80M
QB Rst 0x80MSrv DETCR init 0x0000 (P) SATA Reset RAW OFF PASS (DOS Table) Worst Count: 00000FF6 At SU: 00004D6F NT: 00000000 OT: 00000110 (POR) Recover Secondary MCMT Opened Recovered (MC POR Duration): 00000001FC Intel 6G->3G Send Status: COMRESET seen CSpd= 3Gbps Common path start quit now ProcessRC: 00000000,00000000ReadContinuous: 028D1FCE,00000186TotalEntries:0000 XfrLen:0186UnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out: SP Regen FAIL SPRegen [0000|03110488] @LBA=0x028D1FCE Setup currentretry count Hd 1 Err Blk 31797AC BER pre -1.881127 Out: Update Mask - 000000001468FE70 - 00000008 - 00 Harden - 028D1FCE InitiateMarkPendingReallocateRequest for disc_lba: 00028D1FCE CHS: 00012BDD.01.0000 Assert 741D - LBA 028D1FCE! Common path start quit now ProcessRC: 00000002,00000000ReadContinuous: 028D1FCF,00000185TotalEntries:0000 XfrLen:0185UnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out: SP Regen FAIL SPRegen [0000|03110488] @LBA=0x028D1FCF Setup currentretry count Hd 1 Err Blk 31797AD BER pre -1.880568 Out: Update Mask - 000000001468FE78 - 00000008 - 00 Harden - 028D1FCF InitiateMarkPendingReallocateRequest for disc_lba: 00028D1FCF CHS: 00012BDD.01.0001 Assert 741D - LBA 028D1FCF! Common path start quit now ProcessRC: 00000002,00000000ReadContinuous: 028D1FD0,00000184TotalEntries:0000 XfrLen:0184UnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out: SP Regen FAIL SPRegen [0000|03110488] @LBA=0x028D1FD0 Setup currentretry count Hd 1 Err Blk 31797AE BER pre -1.880385 Out: Update Mask - 000000001468FE80 - 00000008 - 00 Harden - 028D1FD0 InitiateMarkPendingReallocateRequest for disc_lba: 00028D1FD0 CHS: 00012BDD.01.0002 Assert 741D - LBA 028D1FD0! Common path start quit now ProcessRC: 00000002,00000000ReadContinuous: 028D1FD1,00000309TotalEntries:0000 XfrLen:0309UnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out: SP Regen FAIL SPRegen [0000|03110488] @LBA=0x028D1FD1 Setup currentretry count Hd 1 Err Blk 31797AF BER pre -1.881700 Out: Update Mask - 000000001468FE88 - 00000008 - 00 Harden - 028D1FD1 InitiateMarkPendingReallocateRequest for disc_lba: 00028D1FD1 CHS: 00012BDD.01.0003 Assert 741D - LBA 028D1FD1! Common path start quit now ProcessRC: 00000002,00000000ReadContinuous: 028D1FD2,00000308TotalEntries:0000 XfrLen:0308UnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out: SP Regen FAIL SPRegen [0000|03110488] @LBA=0x028D1FD2 Setup currentretry count Hd 1 Err Blk 31797B0 BER pre -1.877858 Out: Update Mask - 000000001468FE90 - 00000008 - 00 Harden - 028D1FD2 InitiateMarkPendingReallocateRequest for disc_lba: 00028D1FD2 CHS: 00012BDD.01.0004 Assert 741D - LBA 028D1FD2! Common path start quit now ProcessRC: 00000002,00000000ReadContinuous: 028D1FD3,00000307TotalEntries:0000 XfrLen:0307UnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out: SP Regen FAIL SPRegen [0000|03110488] @LBA=0x028D1FD3 Setup currentretry count Hd 1 Err Blk 31797B1 BER pre -1.880770 Out: Update Mask - 000000001468FE98 - 00000008 - 00 Harden - 028D1FD3 InitiateMarkPendingReallocateRequest for disc_lba: 00028D1FD3 CHS: 00012BDD.01.0005 Assert 741D - LBA 028D1FD3! Common path start quit now ProcessRC: 00000002,00000000ReadContinuous: 028D1FD4,00000306TotalEntries:0000 XfrLen:0306UnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out: SP Regen FAIL SPRegen [0000|03110488] @LBA=0x028D1FD4 Setup currentretry count Hd 1 Err Blk 31797B2 BER pre -1.880903 Out: Update Mask - 000000001468FEA0 - 00000008 - 00 Harden - 028D1FD4 InitiateMarkPendingReallocateRequest for disc_lba: 00028D1FD4 CHS: 00012BDD.01.0006 Assert 741D - LBA 028D1FD4! the last part keep repeating forever |
| Author: | Martin [ November 21st, 2017, 7:50 ] |
| Post subject: | Re: ST1000LM035-1RK172 BSY |
Pending process + scratch panel updating. You can wait till it finish, but better to use terminal commands in order to switch-off background processes. |
| Author: | Orizarrb [ November 28th, 2017, 14:36 ] |
Not quite sure, but this may help: To get the terminal and to work with service area read the ROM in Boot Code, then unlock techno-mode, write changes and restart drive. Then unlock the drive prepared by utility and press Ctrl+Z (many times right after unlocking) And don't forget to save 28! |
| Author: | lifeguarddubai [ December 3rd, 2017, 5:34 ] |
save 28,35,1B uncheck 93 dont clear SMART its Rosewood. 346 backup as well. |
| Author: | hamidbid [ March 11th, 2018, 6:06 ] |
Hi to all I have the same problem but after read ROM with terminal and apply patch no different and i don't access to SA Boot 0x80M Tech Unlock Handshake: 0xB7824A6D Reply: QB Rst 0x80MSrv DETCR init 0x0000 (P) SATA Reset RAW OFF PASS (DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000 (POR) Recover Secondary MCMT Opened Recovered (MC POR Duration): 0000000147 Intel 6G->3G Send Status: COMRESET seen CSpd= 3Gbps Common path start quit now ProcessRC: 00000000,00000000ReadContinuous: 00E799B4,00000180TotalEntries:0000 XfrLen:0180UnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out: SP Regen FAIL SPRegen [0000|03110488] @LBA=0x00E799B4 Setup currentretry count Hd 0 Err Blk 198E89A BER pre -1.956027 Out: Update Mask - 00000000073CCDA0 - 00000008 - 00 Harden - 00E799B4 InitiateMarkPendingReallocateRequest for disc_lba: 0000E799B4 CHS: 00009AEE.00.0000 Assert 741D - LBA 00E799B4! Common path start quit now ProcessRC: 00000002,00000000ReadContinuous: 00E799B5,0000017FTotalEntries:0000 XfrLen:017FUnrecovSectorCount:0000,0000NumUDEs: 00000000,00000000Failed: 40000087Out: SP Regen FAIL SPRegen [0000|03110488] @LBA=0x00E799B5 Setup currentretry count and repeated "Common path start quit now ProcessRC" Are you have any idea ? |
| Author: | recuperodatiharddisk [ March 12th, 2018, 6:23 ] |
This Issue can be solved editing drive config. With PC3000 you can edit drive parameters. if you dont have PC3K from a term session check those useful commands ( they really work ! ) https://www.data-medics.com/forum/seaga ... -t901.html |
| Author: | hamidbid [ March 17th, 2018, 4:13 ] |
hi unfortunately , I don't have access to sysfiles for backup important modules and edit HDD id |
| Author: | MindMergepk [ March 17th, 2018, 9:04 ] |
hamidbid wrote: hi unfortunately , I don't have access to sysfiles for backup important modules and edit HDD id do you have terminal access ? what do you mean you don't have access to sysfiles ? what tools you are using ? |
| Author: | hamidbid [ March 18th, 2018, 6:10 ] |
MindMergepk wrote: hamidbid wrote: hi unfortunately , I don't have access to sysfiles for backup important modules and edit HDD id do you have terminal access ? what do you mean you don't have access to sysfiles ? what tools you are using ? pc3000 udma and i recoved this models minimum 15 time , but this times its different and after read ROM and apply patch restart the utility i dont have access to sa described in below link http://blog.acelaboratory.com/pc-3000-f ... rives.html |
| Author: | MindMergepk [ March 18th, 2018, 8:52 ] |
can check remotely, PM me if interested. |
| Author: | reco [ July 19th, 2018, 22:20 ] |
use virtual start, it might work. |
| Author: | zoziano [ October 14th, 2018, 14:07 ] |
Own a Dell 7779, by far the worst laptop I have ever owned in my life. 100% disk usage, hasn't worked right since the day I bought it, I have a 100% Walmart tablet windows 10 laptop that runs faster then this Dell I paid over $1100 for. |
