ST380013AS
http://forum.hddguru.com/viewtopic.php?f=11&t=36099
Author:  zekimuren [ November 21st, 2017, 8:33 ]
Post subject:  ST380013AS
Hi
I got SEAGATE BARRACUDA ST380013AS it gets ready and Drive ID is full and correct When I do sector edit or enter any command hdd is busy. Terminal window is:
Author:  zekimuren [ November 21st, 2017, 8:34 ]
Post subject:  Re: ST380013AS
What is do hdd reboot? and What is meaning wrong in terminal?
Author:  pclab [ November 21st, 2017, 10:09 ]
Have you tried to do a headmap and select each one and test?
Seems to be a bad head...
Author:  lifeguarddubai [ November 22nd, 2017, 2:36 ]
Agree with Split Heads seems bad,
try swap Donor Heads before that try using Seagate Utility while creating Task with LDR..
Author:  zekimuren [ November 23rd, 2017, 7:55 ]
Firstly, Thanks a lot for response. İn this case, PC 3000 dont allow creating head map. I saw HDD ID and SERIAL Number. But If I want to read sector But HDD can read so little sector then HDD stoped. Dırectly, Before that I swap head from donor disk to patient disk. What should I do?
Author:  labtech [ November 23rd, 2017, 11:42 ]
Can test heads manually in terminal. Check manual on how.
Author:  Phaz [ November 28th, 2017, 14:21 ]
It can be a pending issue with bad heads. Create a task with active utility actions, and try to solve the pending issue with head map changing at once.
