| SM2246EN Controller SSD. http://forum.hddguru.com/viewtopic.php?f=11&t=36416 |
Page 1 of 1 |
| Author: | fzabkar [ February 11th, 2018, 20:14 ] |
| Post subject: | Re: SM2246EN Controller SSD. |
FWIW, ISTR one PCB design where one could reach safe mode by shorting the NAND R/B pin(s) to ground. Can you see NAND solder balls on the other side of the PCB? Perhaps the other side is not populated ... H27QEGDVEB, SK hynix, 256Gbit, 3.3V, x8, FBGA-132ball, 4MB block, QDP stack, ONFi 3.0: https://www.skhynix.com/static/filedata ... do?seq=281 Code: H = hynix
27 = NAND flash Q = power supply Q = 3.3V/MLC (S = 1.8V/SLC, U = 3.3V/SLC) EG = density EG = 256Gb (CG/DG/EG/FG/1T/2T/4T = 64G/128G/256G/512G/1T/2T/4Tb) D = organisation D = x8 (8 = x8) V = classification E = mode B = version - 3rd generation |
| Author: | bayerecep [ February 12th, 2018, 15:49 ] | ||
| Post subject: | Re: SM2246EN Controller SSD. | ||
this front ssd
