ST500DM002 Terminal Problem
Posted: February 26th, 2018, 2:00
Hello everybody
I have a case Seagate ST500DM002 drive. It can spin up, producing some unusual sounds while initializing (not head clicking) and stays at BSY state, no ID no service area access. And this is terminal output:
When I talk to ACELAB technical support he said try short circuit reading bus line and try to reach terminal but it didn't work. I can not work with terminal. Does anybody have any knowledge or advice for this situation?
Thank you..
- Code:
Boot 0x10M
Spin Up[0x00000000][0x0000BA10]
Trans.
Rst 0x10M
MC Internal LPC Process
Spin Up
FAIL Op=0900 Resp=0005
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 060DA288 060D8574
Seg Write Preamble VBM start: 00000D3C end: 00000D63
Footer - start: 00000D65 end: 00000D8C
Seg Read Preamble VBM - start: 00000D8E end: 00000DB5
Footer - start: 00000DB7 end: 00000DDE
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 22E0
Nonvolatile MCMT sequence number 00008FAF
[RSRS] 193E
ProcessRWError -Read- at LBA 000DCEC6 Sense Code=40000087
ProcessRWError -Read- at LBA 000DCEC7 Sense Code=40000087
FAIL Op=008F Resp=0003
FAIL Op=0155 Resp=0005
InitiateMarkPendingReallocateRequest for disc_lba: 000DCEC7!
Reconstruction: Completed 1:
[MCMTWS]
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00000041
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00000041
MCMainPOR: Feature Enabled...
Starting LBA of RW Request=001320D3 Length=0000014C
ProcessRWError -Read- at LBA 001320D9 Sense Code=43110081
ProcessRWError -Read- at LBA 00132175 Sense Code=43110081
RTL exceeded
ProcessRWError -Read- at LBA 00132177 Sense Code=40000087
FAIL Op=0055 Resp=0005
RTL exceeded
ProcessRWError -Read- at LBA 0013217C Sense Code=40000087
RTL exceeded
ProcessRWError -Read- at LBA 0013217F Sense Code=40000087
RTL exceeded
Starting LBA of RW Request=00132183 Length=0000009C
ProcessRWError -Read- at LBA 00132184 Sense Code=43110081
RTL exceeded
FAIL Op=0065 Resp=0005
Thank you..
