| Which Software Repair BAD SECTOR? http://forum.hddguru.com/viewtopic.php?f=11&t=36627 |
Page 1 of 1 |
| Author: | MKONJKAV [ March 29th, 2018, 13:11 ] |
| Post subject: | Which Software Repair BAD SECTOR? |
Hi , I am looking for software to remove or repair bad sector... |
| Author: | data-medics [ March 29th, 2018, 13:22 ] |
| Post subject: | Re: Which Software Repair BAD SECTOR? |
I believe this is the correct tool to use:
| Author: | ddrecovery [ March 29th, 2018, 14:01 ] |
I think he wanted something a little softer..... |
| Author: | data-medics [ March 29th, 2018, 14:25 ] |
ddrecovery wrote: I think he wanted something a little softer..... Same end result. |
| Author: | ddrecovery [ March 29th, 2018, 14:25 ] |
| Author: | MKONJKAV [ March 29th, 2018, 14:39 ] |
Very funny guys, Thanks for help, Thats show how pro you guys are,if you cant help just show your good personality, i bet if you were in front of me you look to sky to count the bird, |
| Author: | ddrecovery [ March 29th, 2018, 15:02 ] |
MKONJKAV wrote: Very funny guys, Thanks for help, Thats show how pro you guys are,if you cant help just show your good personality, i bet if you were in front of me you look to sky to count the bird, The reason we are being like this is that there is no software to repair bad sectors. Someone told you this in the previous post but you continue to post to try and find the 'magic' software which does not exist. Bad sectors are usually physical damage to the media surface of failing read-write heads which cannot be repaired (at least only by a pro). If you have a lot of bad sectors then the drive is degrading and you need to pull the data off and throw the drive into the trash as advised. |
| Author: | COD [ March 30th, 2018, 10:28 ] |
Bad sector need to visit psyhologist. After many hours, they may become good. |
