| Manually Uploading WD Encryption Key http://forum.hddguru.com/viewtopic.php?f=11&t=36632 |
Page 1 of 1 |
| Author: | ddrecovery [ March 30th, 2018, 13:43 ] |
| Post subject: | Manually Uploading WD Encryption Key |
I have a drive that cannot find the encryption key as the sectors look blank. This is a new fiirmware bug that Ace is working on. However I do have a copy of the SA. I presume I upload the encryption module (25) into the decryption windows. However if I select either 'Add From Folder' or 'Add From File' and select 25.rpm, nothing shows in the window? |
| Author: | MindMergepk [ March 30th, 2018, 13:56 ] |
| Post subject: | Re: Manually Uploading WD Encryption Key |
what is the drive detail ? did you try go back to last version, may be it help you? |
| Author: | ddrecovery [ March 30th, 2018, 13:58 ] |
MindMergepk wrote: what is the drive detail ? did you try go back to last version, may be it help you? Drive is a WD40NMZW. Do you mean the last version of PC3000? |
| Author: | MindMergepk [ March 30th, 2018, 14:04 ] |
yes last version pc3k. Is it a spyglass family if am not wrong ? |
| Author: | labtech [ March 30th, 2018, 17:17 ] |
michael chiklis has a good tutorial with manual work: https://www.youtube.com/watch?v=_qrs7Pg ... e=youtu.be I tested on a few WD drives. It works well. |
| Author: | Doomer [ April 1st, 2018, 22:10 ] |
AFAIK decryption for Spyglass is not supported by PC3K |
| Author: | labtech [ April 1st, 2018, 22:34 ] |
Oooops, forgot that was a Spyglass. |
| Author: | Yustik [ April 2nd, 2018, 2:38 ] |
return SED back and read data |
| Author: | ddrecovery [ April 2nd, 2018, 12:22 ] |
Yustik wrote: return SED back and read data There is no encryption key on the drive anymore. See my initial post. |
| Author: | Doomer [ April 2nd, 2018, 22:11 ] |
ddrecovery wrote: Yustik wrote: return SED back and read data There is no encryption key on the drive anymore. See my initial post. It's not the key problem but translation |
| Author: | ddrecovery [ April 3rd, 2018, 11:52 ] |
Doomer wrote: It's not the key problem but translation Can you elaborate please... |
| Author: | Yustik [ April 4th, 2018, 14:55 ] |
ddrecovery wrote: Doomer wrote: It's not the key problem but translation Can you elaborate please... it works like flash or ssd translator. if you have translated LBA - drive reading and return data, if not translated - return zeroes, because no info about data placement |
| Author: | ddrecovery [ April 9th, 2018, 11:51 ] |
Yustik wrote: it works like flash or ssd translator. if you have translated LBA - drive reading and return data, if not translated - return zeroes, because no info about data placement But wouldn't that return an ABRT or AMNF error? |
| Author: | Yustik [ April 13th, 2018, 1:55 ] |
ddrecovery wrote: Yustik wrote: it works like flash or ssd translator. if you have translated LBA - drive reading and return data, if not translated - return zeroes, because no info about data placement But wouldn't that return an ABRT or AMNF error? why new SSD not return ABRT or AMNF? |
