 Post subject: Manually Uploading WD Encryption Key
PostPosted: March 30th, 2018, 13:43
I have a drive that cannot find the encryption key as the sectors look blank. This is a new fiirmware bug that Ace is working on. However I do have a copy of the SA. I presume I upload the encryption module (25) into the decryption windows. However if I select either 'Add From Folder' or 'Add From File' and select 25.rpm, nothing shows in the window?
 Post subject: Re: Manually Uploading WD Encryption Key
PostPosted: March 30th, 2018, 13:56
what is the drive detail ?
did you try go back to last version, may be it help you?
Data Recovery Pakistan
PostPosted: March 30th, 2018, 13:58
Drive is a WD40NMZW. Do you mean the last version of PC3000?
PostPosted: March 30th, 2018, 14:04
yes last version pc3k.
Is it a spyglass family if am not wrong ?
PostPosted: March 30th, 2018, 17:17
michael chiklis has a good tutorial with manual work: https://www.youtube.com/watch?v=_qrs7Pg ... e=youtu.be
I tested on a few WD drives. It works well.
PostPosted: April 1st, 2018, 22:10
AFAIK decryption for Spyglass is not supported by PC3K
PostPosted: April 1st, 2018, 22:34
Oooops, forgot that was a Spyglass.
PostPosted: April 2nd, 2018, 2:38
return SED back and read data
PCR extracting. Remote data recovery from DVR. Skype: yustik74
PostPosted: April 2nd, 2018, 12:22
There is no encryption key on the drive anymore. See my initial post.
PostPosted: April 2nd, 2018, 22:11
It's not the key problem but translation
PostPosted: April 3rd, 2018, 11:52
Can you elaborate please...
PostPosted: April 4th, 2018, 14:55
it works like flash or ssd translator. if you have translated LBA - drive reading and return data, if not translated - return zeroes, because no info about data placement
PostPosted: April 9th, 2018, 11:51
But wouldn't that return an ABRT or AMNF error?
PostPosted: April 13th, 2018, 1:55
why new SSD not return ABRT or AMNF? :-)
