| Flash boot code checksum failure! on ST2000DM001 http://forum.hddguru.com/viewtopic.php?f=11&t=36957 |
Page 1 of 1 |
| Author: | Paulfromsurrey [ June 17th, 2018, 13:05 ] |
| Post subject: | Flash boot code checksum failure! on ST2000DM001 |
I need some help I have this drive and it was clicking . we find the right donor and replaced the head now after the head is replaced on pc3000 terminal I am getting the following error drive show busy and can not read Here is the drive information look like rom is corrupt Model no: ST2000DM001 PART NO PYN164-500 FW CC4B wwn 5000c500497d2b25 date 12407 site wu Terminal log shows as follows SEA4 Boot ROM 2.0 (05/03/2010) Copyright Seagate 2010 Flash boot code checksum failure! SEA4 Boot ROM 1.0 (05/03/2010) Copyright Seagate 2010 Flash boot code checksum failure! SEA4 Boot ROM 1.0 (05/03/2010) |
| Author: | pcimage [ June 17th, 2018, 14:37 ] |
| Post subject: | Re: Flash boot code checksum failure! on ST2000DM001 |
Have you removed or switched the ROM at any point? |
| Author: | fzabkar [ June 17th, 2018, 16:11 ] |
If you upload your ROM dump, I could check it for you. |
| Author: | michael chiklis [ June 30th, 2018, 16:20 ] |
Code: Flash boot code checksum failure! SEA4 Boot ROM 1.0 (05/03/2010) Usually that happens when rom chip pins have bad soldering joints to pads (in this case motor will not even spin). Check rom pins under microscope, if you see that soldering is bad then solder it again properly by using Amtech or MG flux paste. Or it might be that rom got damaged. |
