| ST3000DM001 Capacity: 3.6 gb. it blocks DRD DSC and ERR ABR http://forum.hddguru.com/viewtopic.php?f=11&t=36987 |
Page 1 of 1 |
| Author: | hvd [ June 21st, 2018, 12:53 ] |
| Post subject: | ST3000DM001 Capacity: 3.6 gb. it blocks DRD DSC and ERR ABR |
Hello I have a hard drive of my client. In PC-3000 it shows the model, SN, FW but Capacity: 3.6 gb. it blocks DRD DSC and ERR ABR I thought there is Head's problem HDD out of service ST3000DM001 S / N: W1F28494 PN: 1CH166-505 FW: CC44 Date: 13296 Site Code: WU PreampType: B4 03 Donor hard drive ST3000DM001 S / N: W1F2QVR5 PN: 1CH166-302 FW: CC26 Date: 13377 Site Code: WU PreampType: CC 06 I tried changing Head Donor but it's the same problem: It shows the model, SN, FW but Capacity: 3.6 gb. it blocks DRD DSC and ERR ABR I searched the hard drive with PreampType: B4 03 on the site donordrives.com, harddrivesforsale.com, ebay but it is not diposible. My question: if the head is not compatible, he can not find the model ? you can use another hard disk with other PreampType that compatible with the hard disk PreampType: B4 03 ? Thanks in advance Cordailement |
| Author: | rogfanther [ June 21st, 2018, 13:28 ] |
| Post subject: | Re: ST3000DM001 Capacity: 3.6 gb. it blocks DRD DSC and ERR |
Just to be sure, did you try the patient head in the donor hdd ? What were the results ? |
| Author: | labtech [ June 21st, 2018, 14:45 ] |
hvd wrote: My question: if the head is not compatible, he can not find the model ? Correct, if the preamp is not compatible, then it cannot read the firmware, which contains the drive model. hvd wrote: you can use another hard disk with other PreampType that compatible with the hard disk PreampType: B4 03 ? Need at least B4 more than likely. |
| Author: | hvd [ June 22nd, 2018, 2:58 ] | ||
| Post subject: | Re: ST3000DM001 Capacity: 3.6 gb. it blocks DRD DSC and ERR | ||
rogfanther wrote: Just to be sure, did you try the patient head in the donor hdd ? What were the results ? Hello Head 4 broke well (see photo). It is possible to disable the Head 4 to read other head. Thank
| Author: | hvd [ June 22nd, 2018, 2:59 ] |
labtech wrote: hvd wrote: My question: if the head is not compatible, he can not find the model ? Correct, if the preamp is not compatible, then it cannot read the firmware, which contains the drive model. hvd wrote: you can use another hard disk with other PreampType that compatible with the hard disk PreampType: B4 03 ? Need at least B4 more than likely. Hello Thanks for your information |
