 Post subject: PC3K-SAS
PostPosted: February 7th, 2017, 5:07
Would like to ask, PC3K-SAS support WD SAS HDD?
 Post subject: Re: PC3K-SAS
PostPosted: February 7th, 2017, 5:39
http://blog.acelaboratory.com/pc-3000-s ... rives.html
PostPosted: February 7th, 2017, 7:45
There's no WD in the blog post, but you can ask ACE support.
PostPosted: February 7th, 2017, 9:41
I'm sure it'll support imaging a WD SAS through Data Extractor. I've never seen or heard of a WD SAS drive with a firmware problem, to be honest. In fact, it's fairly rare across most all SAS drives. Usually they are just catastrophic failures, or bad sectors, occasionally bad heads.
PostPosted: February 7th, 2017, 10:37
Ah, the old trick of trying to fool your RAID into thinking it's the original drive.
PostPosted: February 7th, 2017, 21:30
Spildit wrote:
http://forum.hddguru.com/viewtopic.php?f=28&t=34949
Do you have any solutions to edit HDD ID (SN & Model info) for WD SAS drive?
Looks like our friend here is looking for a way to edit Model and SN on WD SAS drives....
Most likely that is the reason why he is looking for a SAS tool.
Yes, we had place the order for PC3K-SAS. I did check the blog ACE list support, found no WD SAS support.
We wish to edit the SN & Model for WD SAS drives. Anyone have solutions, please PM me. We will pay the service charge if success.
WD SAS:
3TB
Model is WD3001FYYG
Thanks for other member reply. Appreciate it.
PostPosted: August 11th, 2018, 20:59
Probably you will get an error even you would change s/n and name of disk.
An error comes as techno key would not pass as pc 3000 does know it for the original disk. Thats the issue not the name of a disk.
It would probably look llike literaly as you try to open with a wrong key no matter the lock looks like the same - lock key mechanism has not the same sequence as your native lock has it on
WD SAS:
3TB
Model is WD3001FYYG
Users browsing this forum: No registered users and 97 guests
