 Post subject: Sandisk SD bad NAND read
PostPosted: October 9th, 2018, 11:08
Banned User
I was trying to read Sandisk SD card, the bytes at the odd position are skipped, I attached a picture that explains the issue.
NAND ID= 45CE9532
How can it be fixed?
 Post subject: Re: Sandisk SD bad NAND read
PostPosted: October 9th, 2018, 20:01
maybe the config for the chip was wrong, or you used 8-bit config when chip is 16-bit.... or the device is refurbished/fake and has a strange byte cut, or a mix step that will fix that..
what is the hex editor you are using there?
what reader did you use and what config?
Users browsing this forum: Majestic-12 [Bot] and 12 guests
