HDD GURU FORUMS
http://forum.hddguru.com/
TOSHIBA DT01ACA050 No user area access
http://forum.hddguru.com/viewtopic.php?f=11&t=37557
Page 1 of 1
Author:  LostDataSa [ October 17th, 2018, 15:47 ]
Post subject:  TOSHIBA DT01ACA050 No user area access
Hi
I got TOSHIBA DT01ACA050 with a bad head (this HDD have only one physical head P0).
After head replacement, I imaged about 10 GB then it starts giving me an error (black sectors).
The drive gets ready and I have access to SA using Hitachi-IBM-ARM 7210DLE6 and everything looks fine but no access to user area ?? Any suggestion?
Attached SA structure test
SA structure test.7z [2.08 KiB]
Downloaded 663 times
Author:  MindMergepk [ October 18th, 2018, 4:03 ]
Post subject:  Re: TOSHIBA DT01ACA050 No user area access
what if you load translators in RAM, does it give access this way ?
Author:  LostDataSa [ October 19th, 2018, 9:25 ]
I did, still no user access :cry:
Author:  hamidbid [ October 19th, 2018, 13:05 ]
Maybe head again gone?pls check again, Do you access to the first 10 gig of HDD?
Author:  LostDataSa [ October 19th, 2018, 23:49 ]
hamidbid wrote:
Maybe head again gone?pls check again, Do you access to the first 10 GB of HDD?
I tried to access the first 10GB again but no access I get UNC error, but I have access to SA while this drive has only one head ??
Author:  hamidbid [ October 20th, 2018, 7:22 ]
Then your head gone again!
Author:  LostDataSa [ October 20th, 2018, 10:33 ]
If the only head is bad, will i have access to SA?
Author:  MindMergepk [ October 20th, 2018, 15:37 ]
yes it is possible...
http://www.phpbb.com/
