HDD GURU FORUMS
http://forum.hddguru.com/
Best way to read a ROM from WD40NMZW-59GX6S1
http://forum.hddguru.com/viewtopic.php?f=11&t=37608
Page 1 of 1
Author:  oliver1996 [ October 29th, 2018, 11:10 ]
Post subject:  Best way to read a ROM from WD40NMZW-59GX6S1
do you have any good advice how to read a ROM from this drive?
Thanks.
Author:  eazycut [ November 15th, 2018, 9:39 ]
Post subject:  Re: Best way to read a ROM from WD40NMZW-59GX6S1
Hi oliver.
Check this link if you have acces to Ace blog - https://blog.acelaboratory.com/boot-rom ... rives.html
There is also a way to reprogram the ROM on newer (sata pcb) WD drives 2.5" when pcb is in busy mode. Need to solder two pins and use MX-safe adapter and follow the regular boot code procedure.
Good luck!
Author:  njzhaobo [ November 16th, 2018, 4:13 ]
i have thhis rom and model
this family need short tv9-tv10 then read rom sucess :lol:
http://www.phpbb.com/
