| HGST HUH721212ALE600 Firmware / identify in pc-3000 http://forum.hddguru.com/viewtopic.php?f=11&t=37673 |
Page 1 of 1 |
| Author: | trumanhw [ November 10th, 2018, 23:32 ] |
| Post subject: | HGST HUH721212ALE600 Firmware / identify in pc-3000 |
Ultrastar DC HC520 He12 HGST HUH721212ALE600 Identifying the device ... Any suggestions? I'm not even sure what to choose from the device category ... i'm fairly new to PC-3000 -- and I have to admit - Determining the family of device with just a short alpha-numeric moniker for the family doesn't make it obvious. Is there a list that lets me identify or classify them ?? Thanks |
| Author: | labtech [ November 10th, 2018, 23:51 ] |
| Post subject: | Re: HGST HUH721212ALE600 Firmware / identify in pc-3000 |
That model is fairly new. No supported in PC3000, yet. Can try entering the utility using one of the other families, though not sure if it will work. |
| Author: | fzabkar [ November 11th, 2018, 1:27 ] |
Can you upload a ROM dump? I have analysed the ROM from a HUH728080ALE600 (WD80EFZX-68UW8N0), so I'm expecting that it will be similar. AFAICT, HGST has also publicly released the VSC which allows reading of the SA. However, I don't know if a Super-ON command needs to be issued beforehand. I can help with this if you know how to use an ATA terminal. FWIW, the WD80EFZX-68UW8N0 is an Aries HC8. |
| Author: | trumanhw [ November 11th, 2018, 14:37 ] |
labtech wrote: That model is fairly new. No supported in PC3000, yet. Can try entering the utility using one of the other families, though not sure if it will work. I tried. (I lose) . how do i get a ROM dump? is there any chance HDDsurgery doesn't appear to have it. could someone else have it? i have good drive connected as well as bad.... yet, i still can't get in. |
| Author: | fzabkar [ November 11th, 2018, 17:53 ] |
(Helium filled HGST) WD80EFZX-68UW8N0 ROM (structural analysis): http://www.hddoracle.com/viewtopic.php?f=153&t=2549 |
