| ST4000DM004 - can't change head map / set max head http://forum.hddguru.com/viewtopic.php?f=11&t=38219 |
Page 1 of 1 |
| Author: | boerge [ March 20th, 2019, 14:13 ] |
| Post subject: | ST4000DM004 - can't change head map / set max head |
Hi Gurus. This drive spins up, clicking two times and spins down with ready state + ABR but IDs fine. Terminal output is following: Boot 0x0100MAF00550001 SpinUp FAIL Servo Op=0100 Resp=0003 0100 9000 0000 0001 0000 9015 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ResponseFrame 1700 0000 0000 4700 0000 0000 0000 0000 0CA6 0000 CE00 0000 CE00 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF 0000 0004 8931 FFA6 007F 0019 0006 0005 Loop=007F FAIL Servo Op=0100 Resp=0003 0100 9000 0000 0001 0000 9015 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ResponseFrame 0000 0000 0000 0000 0000 0000 0000 0000 18F4 0000 CE00 0000 CE00 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF 0000 0004 8931 FFA5 007F 0031 0006 0000 Loop=007F Probably it's bad heads, so i read ROM via "utility extensions-> work with flash rom" and tried to do log/phys head map editing/set max head to 0 in ROM but always get following error "Can Not Set up Head Map Info". Can anybody help ? Regards, Boerge |
| Author: | pcimage [ March 20th, 2019, 15:02 ] |
| Post subject: | Re: ST4000DM004 - can't change head map / set max head |
As far as I know, this model is not supported for head map yet. |
| Author: | pepe [ March 28th, 2019, 19:40 ] |
Hello, this one is V11, not natively supported by pc3k, but i have solution to work with it. pepe |
