| DE HFS Calculate Size larger than drive size!!! http://forum.hddguru.com/viewtopic.php?f=11&t=38834 |
Page 1 of 1 |
| Author: | turnback101 [ August 31st, 2019, 10:25 ] |
| Post subject: | DE HFS Calculate Size larger than drive size!!! |
Not the first time I have seen it, and I am sure there is a perfectly good reason, but why is it when I sometimes do a ‘calculate size’ on the full root of a HFS partition, i discover the amount of calculated Data is larger than the size of the drive? For Example I have a 1TB drive that I can read perfectly, but with Data Extractor, the amount of extractable data is 1.4TB. |
| Author: | fzabkar [ August 31st, 2019, 17:16 ] |
| Post subject: | Re: DE HFS Calculate Size larger than drive size!!! |
When a new file overwrites part of a deleted file, the two recovered files will share the same space. One file will be intact, the other corrupt. |
| Author: | trumanhw [ September 14th, 2019, 22:01 ] |
fzabkar wrote: When a new file overwrites part of a deleted file, the two recovered files will share the same space. One file will be intact, the other corrupt. Dayum! That's some knowledge there! (Looks like about 15-20 years of Data Recovery acumen to me) |
