 Post subject: rosewood abr error
PostPosted: October 26th, 2019, 6:56
Hello there. I have a rosewood dm35 1 tb disc. Device error detected "ABR". terminal is working. id cannot. all system files can be read and backed up. Translator command successful. but again can not id. abr error rosewood. Do you think there is a solution?
 Post subject: Re: rosewood abr error
PostPosted: October 26th, 2019, 8:21
Have a few questions
What tool do you use?
How do you unlock if terminal is not working?
What "translator command" is successful?
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: October 26th, 2019, 9:45
I'm using PC3K. terminal lock is on. all sysfile backed up.
m0,6,2,,,,,22 succesful
"abr" error continues.
PostPosted: October 26th, 2019, 10:13
Boot 0x80M
Tech Unlock Handshake: 0x9678E8F8
Reply:
QB
Rst 0x80MSrv DETCR init 0x0000
PrgF
(P) SATA Reset
RAW OFF
PASS
(DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000
(POR) Recover Secondary MCMT Opened Recovered
MSP213
(MC POR Duration): 00000000D6
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
DSC
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>V40
Nonresident GList                    0 entries returned
Total entries available: 0
          PBA           Len  Flags  Phy Cyl Hd  PhySctr    SFI
F3 T>V4
Reassigned Sectors List Enabled
Entries: 0000, Alts: 0000, Removed: 0000,
Pending: 0000, Host Pending: 0000, Max RSL Size: 00002000
Idx  LBA          PBA          LLLCHS of LBA Wdg PLPCHS of PBA SFI    Hours Msecs  Status   BBM Mask
F3 T>/1
F3 1>N1
Clear Current Device Internal Status Log
Clear SMART is completed.
F3 1>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/
F3 T>m0,6,2,,,,,22
Max Wr Retries = 08, Max Rd Retries = 32,  Max Iterations = FF, Max Certify Rewrite Retries = 14E8
Ev LBA/Soft XferLen  Zn Trk      Hd Sct  Wdg  PBA      ErrCode
(DOS) File Save Pass  Wrst Ct: 0000 SU: FFFFFFFF NT: 00000000 OT: 00000000
MCMainPOR: Start:
Media Cache Data Base  00747B05D8
MCInitialize: Start:  Host VBM Size (Bytes): 00000210 Metadata VBM Size (Bytes):   Starting LBA 00747B05D8, Count 01CF8718..
ClearMC:  Completed, Last LBA 00764A8CF0
TCC:0020:002F
MCInitialize:  MC Cleared
MCInitialize:  MCMTBufferPtr->Header.MCMTHeader.MediaCacheDiscStateFlags = 0000000A
MCInitialize:  MCMTBufferPtr->Header.MCMTHeader.MCStateFlagsDisc = 00000001
MCInitialize:  MCStateFlags = 00000001
MCMT Save:Pass
MCInitialize: Init complete:
MCMainPOR: MediaCacheDiscStateFlags 00000022  MCStateFlags 00000040
(MC POR Duration): 000001A879
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Total capacity 00000EEE9096 PBAs. SMR spares left 0 PBAs [+0.00e-0%], UMP spares left 3055C PBAs [+7.90e-2%].
F3 T>
Boot 0x80M
Tech Unlock Handshake: 0xA24425A0
Reply:
QB
PrgF
(P) SATA Reset
RAW OFF
PASS
MSP213
(MC POR Duration): 000000003C
Intel 6G->3G
CSpd= 3Gbps
DSC
FAFH_TRIGGER_POWER_UP
PostPosted: October 26th, 2019, 10:30
Translator regeneration wasn't necessary .
PostPosted: October 26th, 2019, 11:51
How to solved problem?
PostPosted: October 26th, 2019, 14:47
Is there anyone to help?
PostPosted: November 7th, 2019, 6:32
Problem solved
PostPosted: March 26th, 2026, 5:29
AYNIADAM, hOW DO YOU Resolved issue of " READING ERROR device error detected "ABR"
of Rosewood Seagate drive , I am facing same problem . Please let me know solution.
