| rosewood abr error http://forum.hddguru.com/viewtopic.php?f=11&t=39069 |
Page 1 of 1 |
| Author: | AYNIADAM [ October 26th, 2019, 6:56 ] |
| Post subject: | rosewood abr error |
Hello there. I have a rosewood dm35 1 tb disc. Device error detected "ABR". terminal is working. id cannot. all system files can be read and backed up. Translator command successful. but again can not id. abr error rosewood. Do you think there is a solution? |
| Author: | digisupport [ October 26th, 2019, 8:21 ] |
| Post subject: | Re: rosewood abr error |
Have a few questions What tool do you use? How do you unlock if terminal is not working? What "translator command" is successful? |
| Author: | AYNIADAM [ October 26th, 2019, 9:45 ] |
I'm using PC3K. terminal lock is on. all sysfile backed up. m0,6,2,,,,,22 succesful "abr" error continues. |
| Author: | AYNIADAM [ October 26th, 2019, 10:13 ] |
Code: Boot 0x80M
Tech Unlock Handshake: 0x9678E8F8 Reply: QB Rst 0x80MSrv DETCR init 0x0000 PrgF (P) SATA Reset RAW OFF PASS (DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000 (POR) Recover Secondary MCMT Opened Recovered MSP213 (MC POR Duration): 00000000D6 Intel 6G->3G Send Status: COMRESET seen CSpd= 3Gbps DSC ASCII Diag mode F3 T> ASCII Diag mode F3 T>V40 Nonresident GList 0 entries returned Total entries available: 0 PBA Len Flags Phy Cyl Hd PhySctr SFI F3 T>V4 Reassigned Sectors List Enabled Entries: 0000, Alts: 0000, Removed: 0000, Pending: 0000, Host Pending: 0000, Max RSL Size: 00002000 Idx LBA PBA LLLCHS of LBA Wdg PLPCHS of PBA SFI Hours Msecs Status BBM Mask F3 T>/1 F3 1>N1 Clear Current Device Internal Status Log Clear SMART is completed. F3 1> ASCII Diag mode F3 T> ASCII Diag mode F3 T>/ F3 T>m0,6,2,,,,,22 Max Wr Retries = 08, Max Rd Retries = 32, Max Iterations = FF, Max Certify Rewrite Retries = 14E8 Ev LBA/Soft XferLen Zn Trk Hd Sct Wdg PBA ErrCode (DOS) File Save Pass Wrst Ct: 0000 SU: FFFFFFFF NT: 00000000 OT: 00000000 (DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000 MCMainPOR: Start: Media Cache Data Base 00747B05D8 MCInitialize: Start: Host VBM Size (Bytes): 00000210 Metadata VBM Size (Bytes): Starting LBA 00747B05D8, Count 01CF8718.. ClearMC: Completed, Last LBA 00764A8CF0 TCC:0020:002F MCInitialize: MC Cleared MCInitialize: MCMTBufferPtr->Header.MCMTHeader.MediaCacheDiscStateFlags = 0000000A MCInitialize: MCMTBufferPtr->Header.MCMTHeader.MCStateFlagsDisc = 00000001 MCInitialize: MCStateFlags = 00000001 MCMT Save:Pass MCInitialize: Init complete: MCMainPOR: MediaCacheDiscStateFlags 00000022 MCStateFlags 00000040 (MC POR Duration): 000001A879 User Partition Format Successful - Elapsed Time 0 mins 00 secs Total capacity 00000EEE9096 PBAs. SMR spares left 0 PBAs [+0.00e-0%], UMP spares left 3055C PBAs [+7.90e-2%]. F3 T> Boot 0x80M Tech Unlock Handshake: 0xA24425A0 Reply: QB Rst 0x80MSrv DETCR init 0x0000 PrgF (P) SATA Reset RAW OFF PASS (DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000 MSP213 (MC POR Duration): 000000003C Intel 6G->3G Send Status: COMRESET seen CSpd= 3Gbps DSC FAFH_TRIGGER_POWER_UP |
| Author: | unknown [ October 26th, 2019, 10:30 ] |
Translator regeneration wasn't necessary . |
| Author: | AYNIADAM [ October 26th, 2019, 11:51 ] |
How to solved problem? |
| Author: | AYNIADAM [ October 26th, 2019, 14:47 ] |
Is there anyone to help? |
| Author: | AYNIADAM [ November 7th, 2019, 6:32 ] |
Problem solved |
| Author: | alexpeter [ March 26th, 2026, 5:29 ] |
AYNIADAM, hOW DO YOU Resolved issue of " READING ERROR device error detected "ABR" of Rosewood Seagate drive , I am facing same problem . Please let me know solution. |
