Help with removing self encryption on a SAS drive
Posted: March 3rd, 2020, 7:17
by nicenswiftly
I am trying to flash firmware onto a SAS HDD, however I believe SED is my problem and not allowing this, what do I need to disable the self encryption on the drive?
I am running CentOS and the drive is ST6000NM0034.
Any advice is much appreciated.
Re: Help with removing self encryption on a SAS drive
Posted: March 3rd, 2020, 10:08
by ddrecovery
How are you trying to flash the firmware?
Posted: March 3rd, 2020, 11:25
by nicenswiftly
ddrecovery wrote:How are you trying to flash the firmware?
I am using sg_write command, I have flash quite a few different drives, a lot with success and 1 type of drive which loosing the capacity however this drive 'ST6000NM0034' I am just getting a response back and I believe it is due to the self encryption on the drive;
Write buffer cmd: 3b 05 00 00 00 00 19 60 00 00
write buffer: Descriptor format, current; Sense key: Illegal Request
ASC=26, vendor specific qualification ASCQ=99 (hex)
Descriptor type: Field replaceable unit
code=0x3f
Descriptor type: Vendor specific [0x80]
00 00 00 00 00 00 00 00 00 00 00 00 00 00
bad field in Write buffer cdb
I hope this answers the question :)
Posted: March 3rd, 2020, 11:33
by ddrecovery
I have not worked on this particular drive, but most newer Seagates have a 'locked' PCB and Firmware which prevents any access to the drive. Looks like yours may be one of those.
Posted: March 3rd, 2020, 12:57
by nicenswiftly
ddrecovery wrote:I have not worked on this particular drive, but most newer Seagates have a 'locked' PCB and Firmware which prevents any access to the drive. Looks like yours may be one of those.
Is there anyway to unlock the PCB if that is what the issue is?
