 Post subject: OCW Mercury Acclesior SSD
PostPosted: April 5th, 2020, 13:22
Good evening everyone,
I have a PCI-SSD adapter (2x240gb Raid 0 modules) one of which seems to have gone ko.
I tried to swap it out of slots and it is actually only 1 that is not recognized, the other is online.
I tried to connect to pc3000 with a sata adapter to capacitors C1, C2, C3, C4 but it is absolutely not detected (I also tried with the working one)
2020-04-04 16_28_47-datarecovery2 - Connessione Desktop remoto.jpg [ 107.86 KiB | Viewed 10435 times ]
 Post subject: Re: OCW Mercury Acclesior SSD
PostPosted: April 9th, 2020, 4:57
I did not make any notes to the one I had last year, just isolated SATA lines from PCIe board and wired them to a SATA connector.
The one i had, both drives was working, one had a few "bads" RAID was a simple stripe set.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: April 10th, 2020, 19:09
Could it be a DEVSLP issue? Check to see if the DC-DC converters are outputting anything.
PostPosted: April 11th, 2020, 4:18
@fzabkar,
OP startet a threat on AceLab forum also, he figured out the connections, but one drive is in safe mode.
PostPosted: April 13th, 2020, 10:04
I made an extreme attempt, moving all the memory modules from the failed card to the working one. I got the same result, safe mode
2020-04-13 13_58_18-datarecovery2 - Connessione Desktop remoto.jpg [ 57 KiB | Viewed 10067 times ]
