| OCW Mercury Acclesior SSD http://forum.hddguru.com/viewtopic.php?f=11&t=39674 |
Page 1 of 1 |
| Author: | digisupport [ April 9th, 2020, 4:57 ] |
| Post subject: | Re: OCW Mercury Acclesior SSD |
I did not make any notes to the one I had last year, just isolated SATA lines from PCIe board and wired them to a SATA connector. The one i had, both drives was working, one had a few "bads" RAID was a simple stripe set. |
| Author: | fzabkar [ April 10th, 2020, 19:09 ] |
Could it be a DEVSLP issue? Check to see if the DC-DC converters are outputting anything. |
| Author: | digisupport [ April 11th, 2020, 4:18 ] |
@fzabkar, OP startet a threat on AceLab forum also, he figured out the connections, but one drive is in safe mode. |
| Author: | fisch88 [ April 13th, 2020, 10:04 ] |
I made an extreme attempt, moving all the memory modules from the failed card to the working one. I got the same result, safe mode Attachment: Attachment: Attachment: 2020-04-13 13_58_18-datarecovery2 - Connessione Desktop remoto.jpg [ 57 KiB | Viewed 10086 times ] |
