| SAMSUNG HN-M101MBB problem http://forum.hddguru.com/viewtopic.php?f=11&t=39843 |
Page 1 of 1 |
| Author: | mojimorady [ May 7th, 2020, 5:54 ] |
| Post subject: | SAMSUNG HN-M101MBB problem |
Dear guru accept my regards it has been for a long time that i am involved with a SAMSUNG HN-M101MBB drive with almost strange problem : when I connect to the PC3K machine , it spins , gets ready state , but when I click to enter utility it becomes busy . (same as WD drives with slow responding problem) , with some effors I could read and save all the modules using terminal not by ATA . when I try to read any module (for example SLIST) by ATA it becomes busy but I could open it by terminal and saved it (SLIST.BIN then I converted it to SLIST.RPM) all the sectors are accessible , the only problem is after 5 seconds the drive becomes BUSY if I click on any menu in PC3K. the terminal putput is as follow: ActiveFW : 00 FWVer : 0001 SATA PLL cal done DDR size detected = 8MB DDR size detected = 8MB *PAUNI_L2957*PA VID=0006 PN=0009 Rev=0002- PA_UNI Found *PAUNI_L2957*PA VID=0006 PN=0009 Rev=0002- PA_UNI FoundU S_0SHK NF Cal:19 SO_1 SPU@30'C,4702mV IS=6 CLA ..36/109 HO..OK HO RPM=3566 OK AC 849 ST..OK mS1 00000003 GT:419 SC(L):4119/89 BE.N:11 LD..OK SK C: 7170 H:0 Loaded FIT ( 0: 0: 1) CalibTable Loaded. Rev:0x1B ResoTable Loaded. Rev:0x01 Bump Limit Loaded. Rev:0x01 RRO1xTable Loaded. Rev:0x01 Fw Active 00 Ovly loaded to 0x00014D00 Ovly loaded to 0x1002E820 FdtTable Loaded. Rev:0x02 DAM Reading Serial Num Pass Up MC PwrOn RRO1x @ H0 Table) cos = -397824, sin = 218368 Coeff) cos = -88651, sin = -48186 DiskSlip : 64 [SrvTrk] DiskSlip : 71 [SrvTrk] PwrOn RRO1x @ H2 Table) cos = -399616, sin = 227840 Coeff) cos = -96720, sin = -83916 DiskSlip : 65 [SrvTrk] DiskSlip : 69 [SrvTrk] TgtCyl: 832 Hd: 0 Zn: 0 Avg.:- 152 TgtCyl: 266976 Hd: 0 Zn: 1 Avg.: 963 SVCAL(0080,0000)-->PASS DAM DAM DAM DAM DAM RecordValid Ok : 0407E47D 0007E41D ReadyTime = 3617894 us ENG>mS1 00000003 SK C:156706 H:0 SC(U)..4119/172 UD..OK : 172 PK_4 C: 27 H:0 I will be appreciated if someone can help me on this special case . be safe of Covid19 Mojtaba |
| Author: | pepe [ May 7th, 2020, 14:21 ] |
| Post subject: | Re: SAMSUNG HN-M101MBB problem |
probably module 93 is damaged. pepe |
| Author: | mojimorady [ May 8th, 2020, 8:47 ] | ||
| Post subject: | Re: SAMSUNG HN-M101MBB problem | ||
Thank you PEPE for the reply I checked the module 93 , it seems it is OK , I upload it here , if you have a chance to check it I will be very appreciated .
| Author: | pepe [ May 8th, 2020, 10:27 ] |
Check mod E5 as well. can you post log when it gets bsy? |
| Author: | DR-Kiev [ May 8th, 2020, 14:57 ] |
There is a chance that problem with FIPS |
| Author: | fzabkar [ May 8th, 2020, 17:00 ] |
ISTR that some drives have a copy of the FIPS in the slack area at the end of some module(s). |
| Author: | DR-Kiev [ May 8th, 2020, 17:27 ] |
Fill it with FF is about to enough , or use from working donor drive . It is stored in ROM , log module . |
| Author: | fzabkar [ May 9th, 2020, 2:14 ] |
There is a copy of the FIPS block in the MOVLY001 module at offsets 0x2E800 - 0x2F7FF, at least in this ST1000LM024 / HN-M101MBB example: http://www.hddoracle.com/viewtopic.php?f=59&t=698&p=12233 |
| Author: | mojimorady [ May 14th, 2020, 4:55 ] |
thank you everybody , I will post the results here and also the terminal messages . thank you again |
| Author: | pepe [ May 21st, 2020, 16:32 ] |
could anybody provide me with ROM and OVL of version 2ARnfj9M_d67 ? thx, pepe |
| Author: | fzabkar [ May 21st, 2020, 17:13 ] |
http://files.hddguru.com/download/SHTR/Burn/ FWIW, there is a 2ARnfj9M.167 file in the burn list. |
| Author: | pepe [ May 22nd, 2020, 4:22 ] |
thx, i will check that too. I got it in the meantime. also checked the OP's fw, coz it hung massively, ie. SATA bsy, no terminal output, no DBG prompt, nothing. So i suspected it might be corrupted but no, it isn't. The case was solved using another fw and some patches, but i think this fw has some bug that got triggered by the sa problems. This is not rare in samsungs pepe |
| Author: | mojimorady [ May 22nd, 2020, 9:49 ] |
Here I should appreciate PEPE, he did me a favor and solved the problem . *************** thank you PEPE *************** |
| Author: | pepe [ May 22nd, 2020, 10:53 ] |
welcome. what bothers me is that we still don't know what the original cause was btw, you could try this: rewrite modules 93,E5,F4 and F5, from another disk. rewrite original ovl (73) rewrite original rom and check what happens pepe |
