WD2.5 COM Port Issue
http://forum.hddguru.com/viewtopic.php?f=11&t=40069
Author:  daRecoM [ June 24th, 2020, 6:16 ]
Post subject:  WD2.5 COM Port Issue
Good day,
I've been using this WD2.5 Com port to read ROM info from WD USB drive for years, and noticed the following error message since a couple of days ago.
HDD Initialization...
Check if COM-port selected correctly and port connection
HDD Initialization...................... : Error
Has anyone encountered this problem before?
Author:  pepe [ June 24th, 2020, 10:21 ]
Post subject:  Re: WD2.5 COM Port Issue
Are you using Acelab serial adapters or some 3rd party? The error might be related to that. I have also noticed they lifted the communication speed to higher rates and it is hardcoded which i told them it would be good to make configurable.
Author:  daRecoM [ June 28th, 2020, 22:09 ]
Hi Pepe,
I'm using Acelab serial adapters.
Thanks.
Author:  pepe [ June 30th, 2020, 17:48 ]
Does the terminal adapter work with other brands?
