Need ROM 2AR20004 for Samsung/Seagate ST1000LM024 or Burn-in
http://forum.hddguru.com/viewtopic.php?f=11&t=40306
Author:  -BR- [ August 18th, 2020, 18:19 ]
Post subject:  Need ROM 2AR20004 for Samsung/Seagate ST1000LM024 or Burn-in
Hi there.
Could someone please share ROM f/w: 2AR20004 from ST1000LM024?
I know there are other methods and this is not the most recommended one, but this particular case original rom is lost, I could not access using burn-in (no compatible one available) and smart hot swap is not possible due to the lack of a proper donor. So I´d like to try some 2AR20004 ROMs to see if i get luck to match the proper OVERLAY
If possible and not too much of a hassle, more than 1 ROM is welcome since they can be different even under the same 2AR20004 f/w version
Thank you all in advance :D
p.s
Also would help any burn in resources for this particular model. The ones from Ace update box do not match any search criteria
Author:  fzabkar [ August 18th, 2020, 18:31 ]
Post subject:  Re: Need ROM 2AR20004 for Samsung/Seagate ST1000LM024 or Bur
Can you show us the terminal log? That should tell us the RAM load points for the overlay components. Then you can locate these same load points in the FLASHTABL in the ROM. If the load points don't match, then you can eliminate that particular ROM candidate.
Are you able to retrieve the overlay via terminal?
Author:  -BR- [ August 18th, 2020, 18:50 ]
Terminal log, using pcb from same rom f/w from hdd label
(original pcb lost by customer)
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
DDR size detected = 16MB
*PAUNI_L2957*PA VID=0006 PN=0009 Rev=0002- PA_UNI Found
*PAUNI_L2957*PA VID=0006 PN=0009 Rev=0002- PA_UNI FoundU
S_0SO_1
SPU@30'C,5020mV
IS=4
CLA ..36/64
HO..OK
HO RPM=1648 OK
AC 1111
ST..Skip..OK
mS1 00000003
GT:421
SC(L):4106/45
BE.N:31
LD..OK
SK C: 7194 H:0
Boot Sector Error!
Loaded FIT ( 0: 0: 1)
CalibTable Loaded. Rev:0x1B
ResoTable Loaded. Rev:0x01
Bump Limit Loaded. Rev:0x01
RRO1xTable Loaded. Rev:0x01
Fw Active 00
| 115 | MOVLY001 | 1 | 0 | 10 | 1140 |
Ovly loaded to 0x00014D00
Ovly NOT loaded
I was able to read all patient modules using dumb hot swap
In this case, drive uses 73 MOVLY001 and 19 BOVLY001
Author:  fzabkar [ August 18th, 2020, 19:13 ]
This is the address that you should look for in the ROM FLASHTABL and in the MOVLY001 header. IIUC, there should be two RAM addresses for two MOVLY001 components.
I can show where to find them, if need be. Just upload your MOVLY001 and ROM samples.
http://www.hddoracle.com/viewtopic.php?f=59&t=698&p=2150#p2150
Author:  fzabkar [ August 18th, 2020, 20:05 ]
I would also confirm that your ROM candidate has a reference to your preamp "PAUNI_L2957", and that the FIPS section contains the same head map.
I believe this is where the head map is located:
http://www.hddoracle.com/viewtopic.php?f=84&t=1933&p=21661#p21661
Author:  -BR- [ August 18th, 2020, 20:06 ]
Thank you for the link with the info!
I hex edited donor ROM and patient MOVLY001 and they both use the same 0x014D00 address, so this case is probably a version compatibility that can not be eliminated by this parameter.
Even if it could, my problem is exactly the oposite: I don't have any other ROMs with this f/w to use as donor ... :(
So if anybody could spare the time, please share ROM(s) with f/w: 2AR20004 from ST1000LM024
On my side I would not mind trying them one by one until one works
Thanks again.
Author:  fzabkar [ August 18th, 2020, 20:15 ]
https://firmware.hddsurgery.com/dl.php?file=18687&filename=HN-M101MBB-2AR20004-S2WZJ90D233528.zip
https://firmware.hddsurgery.com/index.php?manufacturer=Samsung&family=M8E
FWIW, here are Samsung burn resources, but I don't know whether they include your model (probably not):
http://files.hddguru.com/download/SHTR/Burn/
Author:  fzabkar [ August 18th, 2020, 20:43 ]
See https://forum.hddguru.com/viewtopic.php?t=28329
Fw Active 00
Ovly loaded to 0x00014D00    <-- first component of MOVLY001
Ovly loaded to 0x1002E408    <-- second component of MOVLY001
FdtTable Loaded. Rev:0x02
Reading Serial Num Pass
Up MC
Author:  -BR- [ August 19th, 2020, 6:14 ]
I looked before but from model ST10000LM024 fw 2AR20004 Hddsurgery DB had only 1 entry with modules only - no ROM
But I tried ajusting another donor ROM and made it compatible.
From here I just ajusted patient SA to work with my donor pcb and everything worked.
Saving customer data now.
Thank you for the suggestion!
Author:  einstein9 [ August 19th, 2020, 10:13 ]
[quote="-BR-"]Hi there.
:wink:
2AR8fxuM_d59_2AR20004.rar [167.22 KiB]
Downloaded 789 times
Author:  -BR- [ August 19th, 2020, 13:41 ]
Thank you for sharing einstein9!
Case was already solved as I posted in last reply
Anyway it is always nice to have some more ROMs, since there are only a few ones available with f/w 2AR20004 in the usual places.
Author:  fzabkar [ August 19th, 2020, 15:46 ]
I guess that means you wrote a donor MOVLY001 module to the SA?
Author:  einstein9 [ August 22nd, 2020, 2:33 ]
hehe, i did not notice..
good luck
