 Post subject: Sadle G6 - H0 fail - hot swap?
PostPosted: September 26th, 2020, 4:55
I've patient - WD20EARX-00PASB0.
The H0 head is damaged due to the damaged surface.
Can I hot swap in such a situation?
How to read the SA modules from the patient needed for a hot swap?
 Post subject: Re: Sadle G6 - H0 fail - hot swap?
PostPosted: October 18th, 2020, 19:21
Banned User
you have to replaced the head assembly.
Optimal casual Dating
PostPosted: October 19th, 2020, 3:49
Surface under H0 is damaged by scratches.
PostPosted: October 19th, 2020, 15:16
What about H1?
PostPosted: December 3rd, 2020, 17:49
Try accessing H1 SA.
If all goes well, you may simply do a HM in ram and have it detected without a need of transplant or swap.
To do HM for such a drive is a generic procedure/protocol(unless you know how to figure that out ). :)
Users browsing this forum: No registered users and 118 guests
