| ST1000LM048 READ BY ID BUT CANNOT WRITE http://forum.hddguru.com/viewtopic.php?f=11&t=40772 |
Page 1 of 1 |
| Author: | SLAB_TEAM0 [ December 29th, 2020, 13:18 ] |
| Post subject: | ST1000LM048 READ BY ID BUT CANNOT WRITE |
Hi, I ask for help, if you can give some advice. Have a Rosewood drive which I have made module backup (by id) of main modules (0+1) using terminal Of course have unlocked SA with patch After backupping, every parameter i try to read in utility status lead the drive in busy state, using direct ata or terminal reading method too. Terminal reply without ctrl+z is Boot 0x80M Tech Unlock Handshake: 0x836417BE Reply: QB Rst 0x80M T:0x0003 0x10F51F03Srv DETCR init 0x0000 FTU (P) SATA Reset RAW OFF PASS (DOS Table) Worst Count: 00000FE4 At SU: 00004B56 NT: 00000000 OT: 00000084 (MC POR Duration): 000000019F Intel 6G->3G Send Status: COMRESET seen CSpd= 3Gbps Update Mask - 0000000043A8B7E0 - 00000008 - 00 Update Mask - 0000000043A8B7E8 - 00000008 - 00 Update Mask - 0000000043A8B7F0 - 00000008 - 00 Update Mask - 0000000043A8B7F8 - 00000008 - 00 Update Mask - 0000000043A8B800 - 00000008 - 00 Update Mask - 0000000043A8B808 - 00000008 - 00 Update Mask - 0000000043A8B810 - 00000008 - 00 Update Mask - 0000000043A8B818 - 00000008 - 00 Update Mask - 0000000043A8B820 - 00000008 - 00 Update Mask - 0000000043A8B828 - 00000008 - 00 Update Mask - 0000000043A8B830 - 00000008 - 00 Update Mask - 0000000043A8B838 - 00000008 - 00 Update Mask - 0000000043A8B840 - 00000008 - 00 Update Mask - 0000000043A8B848 - 00000008 - 00 Update Mask - 0000000043A8B850 - 00000008 - 00 Update Mask - 0000000043A8B858 - 00000008 - 00 Update Mask - 0000000043A8B860 - 00000008 - 00 Update Mask - 0000000043A8B868 - 00000008 - 00 Update Mask - 0000000043A8B870 - 00000008 - 00 Update Mask - 0000000043A8B878 - 00000008 - 00 Update Mask - 0000000043A8B880 - 00000008 - 00 Update Mask - 0000000043A8B888 - 00000008 - 00 Update Mask - 0000000043A8B890 - 00000008 - 00 Update Mask - 0000000043A8B898 - 00000008 - 00 Update Mask - 0000000043A8B8A0 - 00000008 - 00 Update Mask - 0000000043A8B8A8 - 00000008 - 00 Update Mask - 0000000043A8B8B0 - 00000008 - 00 Update Mask - 0000000043A8B8B8 - 00000008 - 00 Update Mask - 0000000043A8B8C0 - 00000008 - 00 Update Mask - 0000000043A8B8C8 - 00000008 - 00 Update Mask - 0000000043A8B8D0 - 00000008 - 00 Update Mask - 0000000043A8B8D8 - 00000008 - 00 Update Mask - 0000000043A8B8E0 - 00000008 - 00 Update Mask - 0000000043A8B8E8 - 00000008 - 00 Update Mask - 0000000043A8B8F0 - 00000008 - 00 Update Mask - 0000000043A8B8F8 - 00000008 - 00 Update Mask - 0000000043A8B900 - 00000008 - 00 Update Mask - 0000000043A8B908 - 00000008 - 00 Update Mask - 0000000043A8B910 - 00000008 - 00 Update Mask - 0000000043A8B918 - 00000008 - 00 Update Mask - 0000000043A8B920 - 00000008 - 00 Update Mask - 0000000043A8B928 - 00000008 - 00 Update Mask - 0000000043A8B930 - 00000008 - 00 Update Mask - 0000000043A8B938 - 00000008 - 00 Update Mask - 0000000043A8B940 - 00000008 - 00 Update Mask - 0000000043A8B948 - 00000008 - 00 Update Mask - 0000000043A8B950 - 00000008 - 00 Update Mask - 0000000043A8B958 - 00000008 - 00 Update Mask - 0000000043A8B960 - 00000008 - 00 Update Mask - 0000000043A8B968 - 00000008 - 00 Update Mask - 0000000043A8B970 - 00000008 - 00 Update Mask - 0000000043A8B978 - 00000008 - 00 Update Mask - 0000000043A8B980 - 00000008 - 00 Update Mask - 0000000043A8B988 - 00000008 - 00 Update Mask - 0000000043A8B990 - 00000008 - 00 Update Mask - 0000000043A8B998 - 00000008 - 00 Update Mask - 0000000043A8B9A0 - 00000008 - 00 Update Mask - 0000000043A8B9A8 - 00000008 - 00 Update Mask - 0000000043A8B9B0 - 00000008 - 00 Update Mask - 0000000043A8B9B8 - 00000008 - 00 Update Mask - 0000000043A8B9C0 - 00000008 - 00 Update Mask - 0000000043A8B9C8 - 00000008 - 00 Update Mask - 0000000043A8B9D0 - 00000008 - 00 Update Mask - 0000000043A8B9D8 - 00000008 - 00 Update Mask - 0000000043A8B9E0 - 00000008 - 00 Update Mask - 0000000043A8B9E8 - 00000008 - 00 Update Mask - 0000000043A8B9F0 - 00000008 - 00 Update Mask - 0000000043A8B9F8 - 00000008 - 00 Update Mask - 0000000043A8BA00 - 00000008 - 00 Update Mask - 0000000043A8BA08 - 00000008 - 00 Update Mask - 0000000043A8BA10 - 00000008 - 00 Update Mask - 0000000043A8BA18 - 00000008 - 00 Update Mask - 0000000043A8BA20 - 00000008 - 00 Update Mask - 0000000043A8BA28 - 00000008 - 00 Update Mask - 0000000043A8BA30 - 00000008 - 00 Update Mask - 0000000043A8BA38 - 00000008 - 00 Update Mask - 0000000043A8BA40 - 00000008 - 00 Update Mask - 0000000043A8BA48 - 00000008 - 00 Update Mask - 0000000043A8BA50 - 00000008 - 00 Update Mask - 0000000043A8BA58 - 00000008 - 00 Update Mask - 0000000043A8BA60 - 00000008 - 00 Update Mask - 0000000043A8BA68 - 00000008 - 00 Update Mask - 0000000043A8BA70 - 00000008 - 00 Update Mask - 0000000043A8BC58 - 00000008 - 00 Update Mask - 0000000043A8BC60 - 00000008 - 00 Update Mask - 0000000043A8BC68 - 00000008 - 00 Update Mask - 0000000043A8BC70 - 00000008 - 00 Update Mask - 0000000043A8BC78 - 00000008 - 00 Update Mask - 0000000043A8BC80 - 00000008 - 00 Update Mask - 0000000043A8BC88 - 00000008 - 00 Update Mask - 0000000043A8BC90 - 00000008 - 00 Update Mask - 0000000043A8BC98 - 00000008 - 00 Update Mask - 0000000043A8BCA0 - 00000008 - 00 Update Mask - 0000000043A8BCA8 - 00000008 - 00 Update Mask - 0000000043A8BCB0 - 00000008 - 00 Update Mask - 0000000043A8BCB8 - 00000008 - 00 Update Mask - 0000000043A8BCC0 - 00000008 - 00 Update Mask - 0000000043A8BCC8 - 00000008 - 00 Update Mask - 0000000043A8BCD0 - 00000008 - 00 Update Mask - 0000000043A8BCD8 - 00000008 - 00 Update Mask - 0000000043A8BCE0 - 00000008 - 00 Update Mask - 0000000043A8BCE8 - 00000008 - 00 Update Mask - 0000000043A8BCF0 - 00000008 - 00 Update Mask - 0000000043A8BCF8 - 00000008 - 00 Update Mask - 0000000043A8BD00 - 00000008 - 00 Update Mask - 0000000043A8BD08 - 00000008 - 00 Update Mask - 0000000043A8BD10 - 00000008 - 00 Update Mask - 0000000043A8BD18 - 00000008 - 00 Update Mask - 0000000043A8BD20 - 00000008 - 00 Update Mask - 0000000043A8BD28 - 00000008 - 00 Update Mask - 0000000043A8BD30 - 00000008 - 00 Update Mask - 0000000043A8BD38 - 00000008 - 00 Update Mask - 0000000043A8BD40 - 00000008 - 00 Update Mask - 0000000043A8BD48 - 00000008 - 00 Update Mask - 0000000043A8BD50 - 00000008 - 00 Update Mask - 0000000043A8BD58 - 00000008 - 00 Update Mask - 0000000043A8BD60 - 00000008 - 00 Update Mask - 0000000043A8BD68 - 00000008 - 00 Update Mask - 0000000043A8BD70 - 00000008 - 00 Update Mask - 0000000043A8BD78 - 00000008 - 00 Update Mask - 0000000043A8BD80 - 00000008 - 00 Update Mask - 0000000043A8BD88 - 00000008 - 00 Update Mask - 0000000043A8BD90 - 00000008 - 00 Update Mask - 0000000043A8BD98 - 00000008 - 00 Update Mask - 0000000043A8BDA0 - 00000008 - 00 Update Mask - 0000000043A8BDA8 - 00000008 - 00 Update Mask - 0000000043A8BDB0 - 00000008 - 00 Update Mask - 0000000043A8BDB8 - 00000008 - 00 Update Mask - 0000000043A8BDC0 - 00000008 - 00 Update Mask - 0000000043A8BDC8 - 00000008 - 00 Update Mask - 0000000043A8BDD0 - 00000008 - 00 Update Mask - 0000000043A8BDD8 - 00000008 - 00 Update Mask - 0000000043A8BDE0 - 00000008 - 00 Update Mask - 0000000043A8BDE8 - 00000008 - 00 Update Mask - 0000000043A8BDF0 - 00000008 - 00 Update Mask - 0000000043A8BDF8 - 00000008 - 00 Update Mask - 0000000043A8BE00 - 00000008 - 00 Update Mask - 0000000043A8BE08 - 00000008 - 00 Update Mask - 0000000043A8BE10 - 00000008 - 00 Update Mask - 0000000043A8BE18 - 00000008 - 00 Update Mask - 0000000043A8BE20 - 00000008 - 00 Update Mask - 0000000043A8BE28 - 00000008 - 00 Update Mask - 0000000043A8BE30 - 00000008 - 00 Update Mask - 0000000043A8BE38 - 00000008 - 00 Update Mask - 0000000043A8BE40 - 00000008 - 00 Update Mask - 0000000043A8BE48 - 00000008 - 00 Update Mask - 0000000043A8BE50 - 00000008 - 00 Update Mask - 0000000043A8BE58 - 00000008 - 00 Update Mask - 0000000043A8BE60 - 00000008 - 00 Update Mask - 0000000043A8BE68 - 00000008 - 00 Update Mask - 0000000043A8BE70 - 00000008 - 00 Update Mask - 0000000043A8BE78 - 00000008 - 00 Update Mask - 0000000043A8BE80 - 00000008 - 00 Update Mask - 0000000043A8BE88 - 00000008 - 00 Update Mask - 0000000043A8BE90 - 00000008 - 00 Update Mask - 0000000043A8BE98 - 00000008 - 00 Update Mask - 0000000043A8BEA0 - 00000008 - 00 Update Mask - 0000000043A8BEA8 - 00000008 - 00 Update Mask - 0000000043A8BEB0 - 00000008 - 00 Update Mask - 0000000043A8BEB8 - 00000008 - 00 Update Mask - 0000000043A8BEC0 - 00000008 - 00 Update Mask - 0000000043A8BEC8 - 00000008 - 00 Update Mask - 0000000043A8BED0 - 00000008 - 00 Update Mask - 0000000043A8BED8 - 00000008 - 00 Update Mask - 0000000043A8BEE0 - 00000008 - 00 Update Mask - 0000000043A8BEE8 - 00000008 - 00 Update Mask - 0000000043A8BEF0 - 00000008 - 00 Update Mask - 0000000043A8BEF8 - 00000008 - 00 Update Mask - 0000000043A8BF00 - 00000008 - 00 Update Mask - 0000000043A8BF08 - 00000008 - 00 Update Mask - 0000000043A8BF10 - 00000008 - 00 Starting LBA of RW Request=0008751220 Length=0000074A ProcessRWError -Read- at LBA 00087517E3 Sense Code=43110081 Common path start quit now EDAC Value = 00000000087516C5 EDAC Value = 00000000087516C5ProcessRC: 00000000,00000000SkipLen: 00000000ReadContinuous: 087516FC,0000026EUnrecovSectorCount:00DA,0136NumUDEs: 000000DA,00000000,00000136Passed: 00000080,000000F8,0000022FOut: PE 43160080 PE 43160080 PE 43160080 PE 43160080 FwIoc SB=087516FC, TB=087517E3, OS 1B 34 42 95 B0 DD E7 120 122 123 124 125 126 127 128 129 12A 12B 12C 12D 12E 12F 130 131 132 133 134 135 136 137 138 IOC: U=1D, P=2, [OC iteration](HU CW count) ConvergedSectorOffset, [1](ACD) [2](AB9) [3](AAF) [4](AA3) [5](A99) [6](A93) [7](A8A) [8](A7D) [9] SP Regen FAIL SPRegen [0000|04090098] @LBA=0x087517E3 Setup currentretry count Hd 1 Err Blk 87517E3 BER pre -1.957706 EDAC Value = 00000000087516C5 EDAC Value = 00000000087516C5Out: Update Mask - 0000000043A8BF18 - 00000008 - 00 Harden - 087517E3 InitiateMarkPendingReallocateRequest for disc_lba: 00087517E3 CHS: 000327D0.01.00E7 Assert 741D - LBA 087517E3! ... .... ... ... ... After patching and quickly entering terminal command enter in T level without displaying any messages. I patched 93 sys file but if I try to write back (indirect ata), hdd go to busy state Anyone could help me please? |
| Author: | smecca [ January 4th, 2021, 8:31 ] |
| Post subject: | Re: ST1000LM048 READ BY ID BUT CANNOT WRITE |
I sent pm. Let me know |
