| Rare FW resources request! http://forum.hddguru.com/viewtopic.php?f=11&t=41306 |
Page 1 of 1 |
| Author: | pcimage [ May 17th, 2021, 12:01 ] |
| Post subject: | Rare FW resources request! |
Hi guys, Looking for startup resources a rare automotive drive I need to unlock. It's an HGST HEJ423232H9E300 with FW Version A200, but any capacity drive should do I have A180 but need A200 Cheers!! |
| Author: | fzabkar [ May 17th, 2021, 14:35 ] |
| Post subject: | Re: Rare FW resources request! |
If you have no luck, try replacing the drive with a WD, then retrieve the password from the WD. I have seen this done at the HDD Oracle with good results. Hopefully the password will not be unique to each drive. |
| Author: | pcimage [ May 17th, 2021, 15:33 ] |
fzabkar wrote: If you have no luck, try replacing the drive with a WD, then retrieve the password from the WD. I have seen this done at the HDD Oracle with good results. Hopefully the password will not be unique to each drive. That’s a good idea! Why didn’t I think of that? |
| Author: | fzabkar [ May 17th, 2021, 15:59 ] |
Remove ATA password from Hitachi Endurastar J4K100 serie: http://www.hddoracle.com/viewtopic.php?f=21&t=570 |
