ST4000NM0035
http://forum.hddguru.com/viewtopic.php?f=11&t=41520
Page 2 of 2
Author:  pepe [ August 26th, 2021, 17:19 ]
Post subject:  Re: ST4000NM0035
Hm, i thought he used a TN03 rom and copied adapts in there.
It will probably work this way...
Author:  Popica [ August 27th, 2021, 2:08 ]
pepe wrote:
i doubt it would do any good, as the CFW is not compatible with the OVLs in the SA.
Did you check it?
AIUI, this firmware keeps a backup copy in a container. The ROM has two "csiD" containers -- one has the original TN03 firmware components while the other has TN05. @E123 has merely reverted to the original container.
It works, i test it...
can i find the way to made the rest of pcs. same as this one?
Thank you @E123 for helping and you guys for your time to reply to me.
Author:  fzabkar [ August 27th, 2021, 2:59 ]
I know what to do, but perhaps you should compensate @E123 for his time. I believe he normally charges a very small sum for Seagate firmware modifications.
Author:  Popica [ August 27th, 2021, 3:53 ]
i will try to do all what i can , hope to can i do it all
Author:  Popica [ August 31st, 2021, 6:28 ]
UPDATE
Thank you @E123 and @fzabkar for your time, i succed also to handle the fully and permanent unlocking on those and reverted to TN05 fw completly unlocked.
Author:  Popica [ October 15th, 2021, 8:53 ]
have now same issue at ST8000NM0045, and that solution dont work like in 4TB seagate...maybe need another step in plus
Author:  fzabkar [ October 15th, 2021, 13:27 ]
Repairing ROM from bad Seagate firmware update:
http://www.hddoracle.com/viewtopic.php?f=59&t=3090
Author:  Popica [ October 18th, 2021, 3:07 ]
here is the 8TB seagate ROM, didnt work the F3 rom explorer on it, still UNLOCK ERROR whent i try to fix it
ST8000NM0045-1RL112 - ZA1E4YTW.rar [490.62 KiB]
Downloaded 465 times
Author:  Popica [ January 31st, 2022, 15:02 ]
i find anothe type of drive but i think the fw its different, i will attach the ROM and logs here, dont work like that one from the past,
on the label its G003, inside two of G00A
maybe someone have an idea
Z1Z2YGJN.rar [205.45 KiB]
Downloaded 328 times
log.log [13.24 KiB]
Downloaded 324 times
terminal data.txt [332 Bytes]
Downloaded 332 times
Page 2 of 2 All times are UTC - 5 hours [ DST ]
