 Post subject: Data extractor convert to one image file
PostPosted: November 8th, 2021, 7:16
I would like to join the .bin files from the data extractor to one single .bin file.
Similar to this topic: https://forum.hddguru.com/viewtopic.php?f=11&t=17004.
I know that it can be done in the GUI but I would need a command line approach. Because I would want to write a script that converts all my backups to a .vmdk (virtual machine disk file) but the tools to convert require a single file.
 Post subject: Re: Data extractor convert to one image file
PostPosted: November 8th, 2021, 13:20
If the files are separated by LBA range, with no additional structure, I think you can try:
copy /B file1.bin+file2.bin+fileN.bin HDD.bin
HDD.bin will be your .bin file
VEXUS Data Recovery
PostPosted: February 10th, 2022, 10:31
Don't do that! In large disks (with many image files) order will be wrong because the file names lengths are not the same.
Just simply export to external file. (Right mouse disk in DE->Export->Export to file).
Users browsing this forum: No registered users and 14 guests
