 Post subject: Loader for WD1502FYPS-02W3B0
PostPosted: April 5th, 2022, 12:31
Hi Guys
Does someone have loader for this WD1502FYPS-02W3B0, ROM version: 00050009
I have tried a few from HDDSurgery, a 2TB version that should have worked, but nothing. Maybe a 1.5TB could do it.
ACELab partner
 Post subject: Re: Loader for WD1502FYPS-02W3B0
PostPosted: April 5th, 2022, 14:50
Not seen any 1.5TB DF4PL RE here, only have 2 TB 00050009 in my db.
Why can´t you use one of those from HDDSurgery ?
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: April 6th, 2022, 2:35
I doubt that the capacity has anything to do with the loader being accepted by the drive or not. It should work, I've done it a million times.
Something else is preventing the drive from accepting the loader, most probably system heads.
PostPosted: April 6th, 2022, 3:10
I suspect that too.
I will have to swap them.
ACELab partner
I get an error when loading.
ACELab partner
PostPosted: April 6th, 2022, 4:35
+1 system heads, as Northwind sugested
