| Loader for WD1502FYPS-02W3B0 http://forum.hddguru.com/viewtopic.php?f=11&t=42300 |
Page 1 of 1 |
| Author: | pclab [ April 5th, 2022, 12:31 ] |
| Post subject: | Loader for WD1502FYPS-02W3B0 |
Hi Guys Does someone have loader for this WD1502FYPS-02W3B0, ROM version: 00050009 I have tried a few from HDDSurgery, a 2TB version that should have worked, but nothing. Maybe a 1.5TB could do it. Thanks |
| Author: | digisupport [ April 5th, 2022, 14:50 ] |
| Post subject: | Re: Loader for WD1502FYPS-02W3B0 |
Not seen any 1.5TB DF4PL RE here, only have 2 TB 00050009 in my db. Why can´t you use one of those from HDDSurgery ? |
| Author: | northwind [ April 6th, 2022, 2:35 ] |
I doubt that the capacity has anything to do with the loader being accepted by the drive or not. It should work, I've done it a million times. Something else is preventing the drive from accepting the loader, most probably system heads. |
| Author: | pclab [ April 6th, 2022, 3:10 ] |
northwind wrote: I doubt that the capacity has anything to do with the loader being accepted by the drive or not. It should work, I've done it a million times. Something else is preventing the drive from accepting the loader, most probably system heads. I suspect that too. I will have to swap them. Thanks |
digisupport wrote: Not seen any 1.5TB DF4PL RE here, only have 2 TB 00050009 in my db. Why can´t you use one of those from HDDSurgery ? I get an error when loading. |
| Author: | digisupport [ April 6th, 2022, 4:35 ] |
+1 system heads, as Northwind sugested |
