ST5000LM000 problem to apply patch
http://forum.hddguru.com/viewtopic.php?f=11&t=42757
Author:  jtb1982 [ October 1st, 2022, 9:09 ]
Post subject:  ST5000LM000 problem to apply patch
How is everyone?
This week I received a st5000lm000 with a somewhat peculiar pcb, when trying to read the rom to try to apply the patch I got the following error message “Boot Code: Can not get current address” as you can see in image 1.png. The device, without making any changes to it, gets ready, and I have access to the data area, and because I don't have the patch applied, I don't have access to the Service Area, which makes it impossible for me to do the head map of the hdd. I need to have the map of heads, because the HD has weak heads.
After this error I made a visual inspection of the pcb and when comparing this pcb with other hdd pcb's of the same model, I could see that the board did not present any type of inscription as can be seen in the image 2.jpg, the rom position differs from a board “standard” as well as the processor package differs from a “standard” board with a QFN package and that of this board is BGA as can be seen in image 3.jpg.
Faced with the impediment to apply the patch with the rom soldered on the board, unsolder the rom I read this in a rom reader and the generated file made pc3k apply the patch, during the patching process several times in the log the messages “Warning ! Segment whole space check sum is invalid!” “Warning! Segment used space check sum is invalid!”, despite the error pc3k performed the patch, as you can see in image 4.png, the rom image with the patch applied I wrote it in the rom and soldered it again in the pcb. I didn't get any positive results because the disc turns on the motor, but at no time is it ready.
And the 5.jpg image is a photo of the client disk.
Has anyone had a similar experience
Thanks Very Much, My Best Regards
File comment: Hdd photo
File comment: Error trying to apply the patch to the rom
File comment: Comparing the position of the ROM and the processor package
File comment: Comparing the inscriptions of this PCB with a standard PCB
File comment: Boot Code: Can not get current address
Author:  pepe [ October 1st, 2022, 11:12 ]
Post subject:  Re: ST5000LM000 problem to apply patch
this is because the drive is M15 family with locked boot terminal and pc3k does not support unlocking it AFAIK
Author:  fzabkar [ October 1st, 2022, 15:15 ]
The checksum errors are probably bogus. Those 3 affected ROM segments don't appear to be checksummed. If you upload your ROM, I can analyse those segments for you.
Author:  jtb1982 [ October 4th, 2022, 17:13 ]
PEPE thanks very much to answer, indeed is not the same family, I forgot to generate the room report in the Seagate utility.
Author:  jtb1982 [ October 4th, 2022, 17:43 ]
FZABKAR Thanks very much to answer, I uploaded the rom to wetransfer, and I share the link. Thanks for taking a look at the rom.
https://we.tl/t-AvzmhOKWzY
Author:  fzabkar [ October 4th, 2022, 18:11 ]
Segment 0x2B contains SMART data which have been updated at hourly intervals.
Serial number is WCJxxxxx
Part number is 027JJ0DTX
ID  Flg  Cur  Wor  Raw             Description
  1  0F    50   38  0007E00C41A6B7  Raw Read Error Rate
  3  03   100  100  00000000000000  Spin Up Time
  4  32    93   93  00000000001C7F  Start/Stop Count
  5  33   100  100  00000000000000  Reallocated Sector Count
  7  0F    69   60  0000000071C9E9  Seek Error Rate
  9  32    98   98  1EB3D90000083D  Power-On Hours Count
10  13   100  100  00000000000000  Spin Retry Count
12  32   100  100  00000000000166  Drive Power Cycle Count
184  32   100  100  00000000000000  End to End Error Det/Corr Count
187  32   100  100  00000000000000  Reported Uncorrectable Errors
188  32    99   96  0000180019001C  Command Time Out
189  3A   100  100  00000000000000  High Fly Writes
190  22    70   49  000000231C001E  Airflow Temperature
191  32   100  100  00000000000000  Shock Sense
192  32   100  100  01000000000024  Emergency Retract Cycle Count
193  32    93   93  000000000037CC  Load/Unload Cycle Count
194  22    30   51  0000130000001E  HDA Temperature
197  12   100  100  00000000000000  Current Pending Sector Count
198  10   100  100  00000000000000  Offline Uncorrectable Sector Count
199  3E   200  200  00000000000000  UltraDMA CRC Error Rate
240  00   100  253  07D50F00000062  Head Flying Hours
241  00   100  253  00000077443E23  Total LBAs written
242  00   100  253  000000C6D6BA8A  Total LBAs read
0014D000_unknown 2Bh.bin.txt.7z [1.13 KiB]
Downloaded 452 times
Author:  jtb1982 [ October 6th, 2022, 14:49 ]
Thanks very much to answer, FZABKAR.
