| Help]How do I load the translator to ram for spyglass drive? http://forum.hddguru.com/viewtopic.php?f=11&t=43052 |
Page 1 of 1 |
| Author: | CrazyDoctor [ January 23rd, 2023, 17:55 ] |
| Post subject: | Help]How do I load the translator to ram for spyglass drive? |
Hi all Long time since I had to do this procedure so I lost the right steps. Please help me I got WD40NMZW-11GX6S1-01.01A01 drive with bad pcb. After converting the USB to SATA and blocked module 02 access I got full SA access but no user data access. How do I load or initilize the drive by loading the translator to RAM to get full drive ID? I attending to this approche because the solution for slow responding drive may damage the original translator so I want to load the translator to ram and use the solve responding solution for the ram only. I hope I succeed to explain myself. How do I load the translator to ram for spyglass drive? Best Regards, |
| Author: | pepe [ January 23rd, 2023, 19:02 ] |
| Post subject: | Re: Help]How do I load the translator to ram for spyglass dr |
write it to ram.... but i doubt that would work after starting it with 02 blocked... |
| Author: | CrazyDoctor [ January 23rd, 2023, 19:48 ] |
pepe wrote: write it to ram.... but i doubt that would work after starting it with 02 blocked... I solved the case, Thank you pepe for your respond |
| Author: | fzabkar [ January 23rd, 2023, 20:32 ] |
Did the original PCB have a dry solder joint at the zero-ohm resistor near the USB connector? |
| Author: | CrazyDoctor [ January 28th, 2023, 13:36 ] |
fzabkar wrote: Did the original PCB have a dry solder joint at the zero-ohm resistor near the USB connector? I didn't check I solved the case by converting the board to sata and did some modifications on the SA. |
