 Post subject: Seagate Hepburn Diagnostics
PostPosted: March 25th, 2023, 23:16
This disk Model -- Seagate Barracuda LP- ST3100052AS (FW- CC38) is spinning normally and is not making clicking noise. It stays busy.
Following is terminal output -
******************** 3/24/2023 8:36:00 PM ********************
Software can`t control COM port signal level for this USB/COM adapter
Selected family......................... : 40, Hepburn
Model by ID............................. :
Loading default settings!
Use the options dialog to review and save utility settings.
Then press OK!
Family default settings loading!
Tech Key...
HDD Redynes timeout (10000)
Detecting SA Phys Sct Size...
Result.................................. : 512
Rd Sys File: vol = A, FID = 32A, Copy = 000...
Receiving file FILE_A_32A_0, length = 524288
Parsing container segment....... Flash ROM image
Segment: CFW
Parsing segment....... CFW
End parsing segment... CFW
Segment: CAP
Parsing segment....... CAP
End parsing segment... CAP
Segment: RAP
Parsing segment....... RAP
End parsing segment... RAP
Segment: SFW
Parsing segment....... SFW
End parsing segment... SFW
Segment: SHELL
Parsing segment....... SHELL
End parsing segment... SHELL
Segment: SAP
Parsing segment....... SAP
End parsing segment... SAP
Segment: IAP
Parsing segment....... IAP
End parsing segment... IAP
End parsing container segment... Flash ROM image
Buff Root FAT searching in RAM.........
OkSearching module table in RAM... .......
OkSearching DT table(RAM, WR) in RAM......
OkSearching DT table(RAM, RD) in RAM......
OkSearching volume 0 file table in RAM....
Rd Sys File: vol = 1, FID = 202, Copy = 000, Offs = 0, Part size = C...
Receiving file FILE_1_202_0, length = 12
Rd Sys File: vol = 1, FID = 202, Copy = 000, Offs = 0, Part size = CC...
Receiving file FILE_1_202_0, length = 204
OkSearching volume 1/2 file table in RAM...
Rd Sys File: vol = 1, FID = 201, Copy = 000, Offs = 0, Part size = C...
Receiving file FILE_1_201_0, length = 12
Rd Sys File: vol = 1, FID = 201, Copy = 000, Offs = 0, Part size = 384...
Receiving file FILE_1_201_0, length = 900
OkSearching volume 3 file table in RAM....
Rd Sys File: vol = 1, FID = 203, Copy = 000, Offs = 0, Part size = C...
Receiving file FILE_1_203_0, length = 12
Rd Sys File: vol = 1, FID = 203, Copy = 000, Offs = 0, Part size = AF8...
Receiving file FILE_1_203_0, length = 2808
OkSearching volume 4/5 file table in RAM...
Rd Sys File: vol = 1, FID = 204, Copy = 000, Offs = 0, Part size = C...
Receiving file FILE_1_204_0, length = 12
Rd Sys File: vol = 1, FID = 204, Copy = 000, Offs = 0, Part size = 42C...
Receiving file FILE_1_204_0, length = 1068
OkRequest for volume 9/A file allocation table in RAM
Rd Sys File: vol = 1, FID = 20A, Copy = 000, Offs = 0, Part size = C...
Receiving file FILE_1_20A_0, length = 12
Rd Sys File: vol = 1, FID = 20A, Copy = 000, Offs = 0, Part size = F0...
Receiving file FILE_1_20A_0, length = 240
OkSearching SMP RAM FID in RAM............
OkSearching Non Resident G-List FID in RAM
OkSearching CFW OVL FID in RAM............
OkSearch for DBA Base in RAM..............
OkSearch for RW Sys File DBA in RAM.......
OkSearch for MCMT RAM FD in RAM...........
Error
What should I do to extract data ? Can someone take controls for this case as well ?
Thank you. Happy Wekend.
 Post subject: Re: Seagate Hepburn Diagnostics
PostPosted: March 28th, 2023, 7:04
Case resolved successfully , Thanks a;; of you.
Users browsing this forum: No registered users and 92 guests
